Taking digital photos
  • mylo
    • 723
    Hey all,
    I've just recently done a "photo shoot" of my type IXc.
    I am using a Canon PowerShot S100 2.1Mp digi cam.
    The problem I have been running into is getting the subject (the sub) in focus. I have been depressing the little "flower" symbol on the cam that is supposed to be for close up shots but I still can't get the darn thing in focus clearly. Short of that, I don't know what to do as the cam is all auto. I wish they made these things so that you could focus them manually. Is there a way ?
    I use this cam simply for the convenience.
    Myles.
  • turbobearcat
    • 404
    Hey all,
    I've just recently
    Hey all,
    Myles.
    I own a Kodak Easyshare CX6445 4.0 meg pix
    Try the auto function and back up just alittle bit, use your zoom
    slightly and that might land you the results your searching for..
    36 inches max..
    • mylo
      • 723
      I'll try backing up a
      I'll try backing up a little and use zoom. (The zoom is lens and not digital which should be better).
      I'm just getting into photographing my models and I can see wanting equipment that allows me to take real close up shots. Has to be digital, again, for the convenience as I don't have a dark room or know how to develop film. ....never mind posting to the web.
      Myles.
      • tom dougherty
        • 1364
        This is not great advice
        This is not great advice for you right now, but....before buying, I went to a camera shop and tested several digital cameras specifically for the ability to shoot closeups. I settled on a Canon PowerShot S1. I can routinely get within 4-5 inches of my models and get crisp shots with excellent resolution. Canon has done an outstanding job with their in-camera image processing algorithms, and I get extremely balanced and detailed images.
        It runs under $300.
        • mylo
          • 723
          Tom,
          That's what I need,
          Tom,
          That's what I need, something I can get inches away from. How much different is the PowerShot S1 from my PowerShot S100 ??
          I've had my S100 since digital cameras first came out several years ago. I'm not above "upgrading" to something that is going to suit my needs.
          Myles.
          • gerwalk
            • Dec 2004
            • 525
            Tom]
            [color=#000000]Tom]
            • steveuk
              • 467
              Myles, if you haven't already
              Myles, if you haven't already gone out and bought a new camera.. I would suggest this -
              place a largish piece of card immediately in front of your model sub (it will help the auto focus), depress the camera botton half way and hold it there - it should make the camera focus on that distance and it should hold that focus locked while it is half depressed. So you can remove the card now and push the camera button the rest of the way in to take the photo. It is best if the camera is held staedy in that position while you lock down the focus and remove the card. I would advise getting one of the little tabletop tripods. Holding the camera still is always good, especially when light levels are not brilliant.
              • mylo
                • 723
                Steve,
                That's a good approach.
                Steve,
                That's a good approach. I'm going to try that next time.
                In my original photos that I took of my type IXc, I had a sky backdrop that had clouds on it. The clouds in the photo were what the cam was focusing on so I replaced that with just a plain blue backdrop hoping that the cam would pick up on the sub.
                When you say "place a card in front" do you simply mean holding a piece of card stock in front of the photo subject, depress halfway (cam does it's focus thing), take the card away, take the shot ? I wonder why the cam would focus on the card but not the sub ?
                In any case, I will try that because, I still haven't bought another cam and am trying to make do.
                Myles.
                • steveuk
                  • 467
                  Yes that's what I mean.
                  Yes that's what I mean. I think the camera finds it easier to focus on a big flat area because there's no mistaking what you are aiming it at. A good solid signal bounces back for the focus sensor. When you are pointing at a small object like your sub I think the camera passes it by and instead focuses on the sky backdrop because the sub is too small for it to recognise. Just my theory, but I found it helps me.
                  If you have a macro setting (the little flower symbol) it should let you get quite close (say 3 inches) to the model and still be able to focus. That way you dont need the piece of card because your model will fill the frame. You may have to experiment to find your closest possible focal distance.
                  Hope this helps.
                    It's also useful if the
                    It's also useful if the camera has some indication in the viewfinder as to where the autofocus mechanism is pointed at. Think of it as the 'sights' that allow you to get the autofocus to do its job where you want it to.
                    • aeroengineer1
                      • May 2005
                      • 241
                      If you are looking to
                      If you are looking to possibly upgrade I would recommend the Konica Minolta Dimage Z3, Z5, or I think that now there is a Z6. I have the Z3 (4 mega pixel) and it has 2 macro settings. I have gotten my lens as close as 1cm away and the pic is still focused. The other reason I bought the camera is that it has a 12 power optical zoom and there is an adapter ring that can be bought to add filters and even add more zoom. I sue it to take pictures of airplanes, and I can make a small cessna fill the window form a half mile away. The only issues that I have with the camera is that the low light performance is not stellar. This problem may have been done away with in the next models. It will also shoot continuous vids with a fast sd card at 30 fps. I think that if you go to ebay you can get one for about $250-$300 for the Z3
                      Adam
                      • mylo
                        • 723
                        Adam,
                        Thanks for that input.
                        Adam,
                        Thanks for that input. I will keep it stored "upstairs" until I need it.
                        Myles.
                          Here's a camera that I'll
                          Here's a camera that I'll be getting to add to my more "professional" digital Canon D30.......
                          It's one of the models of cameras made by HP and is called the HP Photosmart R817. The thing that makes this potentially very useful to us R/C sub types is that HP offers an underwater case as an option.
                          p.s. I do work for HP, but I am not associated with the imaging division in any way.
                            Jeff,
                            Isn't anyone making a water
                            Jeff,
                            Isn't anyone making a water proof camera anymore? Sony had one out a few years ago good to 5 ft. Shoots video too.
                            I'm in the market as dummy here got my good Sony wet and it no more. Gee I wonder how that happened! LOL!
                              When all else fails read
                              When all else fails read the instruction manual.
                              Find out what the miniumum (closest) focusing distance is and keep your camera to subject distance no closer than that. Then point your camera at something on your model (or that card) that you want the focus on and push the shutter button about half way down. That pre-focuses the lens. Then, keeping the button half way, take the card away and then push the button all the way down. That takes the photo.
                              If you need a closer (more macro shot) - just open the image you just took in a simple photo editing program and crop it closer. If your camera is 2MP or more, you can crop it 50% or better and it will still be sharp enough for internet posting.
                              Steve - here's a new 5MP underwater digital camera that looks pretty good.
                              See it at http://www.sealife-cameras.com/cameras/dc500.html
                              Edited By TMSmalley on 1130894541
