Revell 1/72 U-Boat Errata - Who's making the necessary changes...?
  • randy wise
    • Mar 2004
    • 9
    G'Day Mates,
    It's already been pointed out that the forward torpedo tube doors are 7mm too long and that the anchor recess is 6.5mm too far back in Revell's new U-Boat kit. Originally I wasn't going to do anything about it, but yesterday I took another look at the starboard hull half and the the anchor recess is spotted directly over the hydroplane fairing. Now it's really bugging me and I'll probably make the required alterations. Is anyone else going to move the anchor recess forward? If so, how will you replace the ultra fine rivet detail that Revell molded onto the hull.
    Randy
  • casey thrower
    • 280
    Well, I'm not anal about
    Well, I'm not anal about a model 99% of the population wouldn't have a clue about anyway. I drilled out the limber holes and that's as far as I'll go as far as mods.
      Randy,
      I hadn't seen that the
      Randy,
      I hadn't seen that the tube doors and/or anchor well are slightly off....but I haven't had much time to really measure out the hull itself.
      ....but there are inaccuracies in the deck....... Particularly the way the slots are done in the various hatches.
      Modifying the hull, to include the rivet detail, is probably not going to be easy. I would note that in this scale, the rivets are really, really small. The ones on this hull are just a bit oversized in terms of their thickness, but probably not enough to bother most folks.
      The best way to replace these rivets would likely be with a paint mask, using the thickness of the paint to represent the rivets.
