Re: 75mHz RFI issues
Yep, putting a non-dual conversion crystal in a dual conversion receiver could cause some significant glitching. A dual conversion crystal is your next step.
Your F14 Transmitter is PPM. (which is FM, by the way). A transmitter that can use PCM mode will be labeled PCM, PCM 512, PCM 1024 or PCM 2048. All the PCM transmitters I've ever seen will also be able to switch modes from PCM to PPM via an external setting (usually a digital setting in a menu).
I'm pretty sure the Futaba 168 receiver is PPM only. The futaba website may tell you somewhere.
