Controls Layout
  • david 2507
    • Dec 2014
    • 3
    Controls Layout
    Hello everyone,
    I am new in the RC submarines world, and I have found your site very interesting
    I am converting a Revell 1:72 Type IX C into a RC model, and I have some questions.
    I revised the forum, but I did not find any answer to my doubts (sorry if there were one).
    Now I am wondering how to set the controls layout. I have a Futaba FC16 Navy 40MHz transmitter (I live in Europe), and it comes with the 2 usual joysticks, plus two linear controls in the middle.
    On the sub, I can control the rudder, and independently each of the port and starbord motors, forward and aft planes, and forward and aft ballast tanks.
    I have seen that sometimes the forward port and starbord planes are independently controlled, in order to get smoother and more realistic turns (like in a plane). If it makes a big difference, I can try to add a second servo for the forward planes, but I am not sure if there is enough room for that.
    I am using Mode 2 in the transmitter, thus on the stick at the right I have Ch. 1 horizontally and Ch. 2 vertically, and at the left Ch. 4 horizontally and Ch. 3 vertically. In the middle the Ch. 5 is the control at the left and Ch 6 the one at the right side.
    I would use Ch 1 for the rudder and Ch 3 for the speed, but I do not have a clear idea of how to set the other controls.
    Normally I would use Ch2 for the pitching angle but, working on the forward or on the aft planes? If I did it in both, the sub would dive horizontally, and that is not very realistic.
    Any idea will be very welcome.
    Happy New Year !!!
    David
    Re: Controls Layout
    My layout is mod 2
    Channel 1 (right side horizontal movement) - Rudder
    Channel 2 (right side vertical movement) - Dive planes (Do not think you should split the planes to move independently) I use front dive planes for this.
    Channel 3 (Left side vertical movement) - Throttle
    Channel 4 (left side horizontal movement) - is empty/fill ballast tanks
    With you having the two props on their own ESC, you might want to talk to Kevin McGenius, no it is actually Kevin McLeod he sells a device called throttle jockey made for exactly what you are doing. He can explain more about it.
    I use another channel for a on/off for a pump that saves gas.
    Another channel for my leveler (ADF2 also a Kevin design) it is set to the aft planes.
    Ultimately it is up to your preferences how you want yours set up.
    • david 2507
      • Dec 2014
      • 3
      Re: Controls Layout
      Hello Salmon,
      Thank you for your answer.
      I will do as you suggest me.
      David
