Ballast system ideas
  • subt1
    • Nov 2014
    • 2
    I am trying to make a mini rov and at the moment am trying to design the ballast system for it.
    Initially I thought of using a bladder in the bottom of the rov and pumping water into and out of it, which would make the rov dive or surface. For this I would use a bladder (I have seen some available primarily used for air but I assume they would take water) a pump which can go in reverse as well and maybe a solenoid/valve (I’m not sure if this is needed or if the pump would stop the water from going the wrong way. Does this sound like it would work? I would obviously then have to make my rov buoyant in the first place; I’m assuming this can be done with foam?
    If this doesn’t work then I might use the method of pumping air into the bladder. My question with is, does the air have to be pumped from a specific tank or can it just pump air from within my rov, I understand the pressure will increase but shouldn’t do by much. What sort of valve would you use with this?
    I’m trying to build it as small as possible so I don’t know if any of these lean towards being a smaller system. Any help/guidance would be appreciated.
    Re: Ballast system ideas
    Welcome to the SubCommittee forum! You've come to the right place for answers.
    Either method that you proposed will work. There are a number of r/c sub guys who have built systems using a bladder as the ballast 'tank.' To get you started with some more details, check out this web link from one of our members:
    Dave does a very good job at explaining how either type of ballast system can be constructed.
    Let us/me know if this helps and please feel free to continue asking questions....we're always glad to help.
      If you want to trim your sub for negative buoyancy or adjust for different water densities, then your initial method of pumping water into a bag will work best.
      If the ballast volume is relatively small, then peristaltic pumps are reversible and don't require a check valve. They permit very accurate metering of the water, but do tend to be a bit slow, which is why they're best suited to smaller volumes.
      Ebay is quite a good place to pick up cheap pumps. Bags suitable for use can be anything from a balloon to something like an iv bag.
      Another solution is to pump into a large syringe instead of a bag.
      • subt1
        • Nov 2014
        • 2
        Thank you for the advice. Will check out the link to compare the two systems again. I want to keep the rob as small and light as possible so i guess peristaltic pumps would be good. I'll do a bit more research and see if there are any other questions that come up....
          One other thing worth mentioning as you say you want to keep things small- peristaltic pumps do tend to be a bit chunky compared with other types of pumps.
