New D & E Easy Sub Driver
  • secrtwpn1
    • 269
    Has anyone seen\used D & E's new Easy Sub Driver? I'm looking for a cheap WTC to use in a 32nd Parallel Type XXIII...
    Thx
    Farlan Clutters
    Hesperia, Calif
    Re: New D & E Easy Sub Driver
    If you are happy with a dynamic diving boat, then it looks fine to me. You might benefit from larger rear planes for diving, and trim the boat to at least decks awash.
    • redboat219
      • Jan 2005
      • 523
      Nothings cheaper than a PVC pipe
        Well yes. However not everyone, can or wants to learn how to build their own units.
        • redboat219
          • Jan 2005
          • 523
          Point well taken...
          Would the 3.5" diameter Easy SD fit inside the 32nd Parallel Hull? ( so far it's available in 2" and 3.5" dia.)
            Point well taken...
            IIRC, the 32nd P had a tight fit with the WTC 3, so I bet the 3.5 is out.
            • redboat219
              • Jan 2005
              • 523
              Guess the 2" ESD out too.
              Maybe if the come out of a 2.5".
              • redboat219
                • Jan 2005
                • 523
                Good news!
                According to Mr. Meriman they'll be coming with a 2.5 easy SD some time soon.
                  I have a 32P Type XXIII that uses a Small World Models 3" WTC. So that would work for you too!
