shafts and linkages - ideas
  • murraywl
    • Oct 2003
    • 3
    Anybody have any ideas or recommendations for plane and rudder linkage seals. I'm planning to use 1/16 wire for both. Seems like all I have seen available are for 1/8 wire or rod. Any noticeable advantage using 1/8?
    End use is for scratch built 1/72 LA class. Any homemade shaft and linkage seal ideas?
  • lundberg
    • 55
    Hi,
    first I tried to scratch
    Hi,
    first I tried to scratch build linkage seals from brass pipe but I never managed to get them 100% water tight, quite often the linkages jammed in the seal as well.
    Now I use only rubber bellows and it works great.
    When it comes to shaft seals I use brass pipes filled with marine grease.
    /Bjorn
      • 1367
      From my research on the
      From my research on the message boards here, I found out that people recommended to just bite the bullet and buy the linkage seals from a reputable vendor.
      They're not that expensive, and they've been tried and tested. I'm pretty sure that Subtech, Thor, and Subconcepts carries ready-to-use seals.
      I'm no expert, but I think that running 1/8" rod over 1/16 would allow for better seals, and Skip's units use a nice high-sealing, low friction product.
      I was toying with the idea of building my own seals at the beginning of my project as well, but a real small amount of cash and a little time for delivery let me concentrate on the fun part of scratch-building the hull nicely.
      Just my two cents worth.
      • murraywl
        • Oct 2003
        • 3
        Thanks for the input. I'll
        Thanks for the input. I'll probably go ahead and get off a few bucks and order some. Sometimes I get obsessed with just trying to come up with a unique idea and make it work.
        bill from jaxville
        • david h
          • 199
          For pushrod seals you could
          For pushrod seals you could use a Nylex plastic nozzle like the ones they use for tiny garden sprinkler systems.Pass a 3/ 32 brass rod through and push some nitro fuel tube over the nozzle. Put a small "O" ring over the end. Glue into a hole in the end cap. Works beaut for me.
          regards,
          dave h
          Sydney, australia
