Weathering a Victorian era submarine...
  • modelnut
    • May 2003
    • 432
    I am about to complete final construction of a kitbashed NAUTILUS a'la Jules Verne. My scale is 186th based on Verne's cardinal measurements of an eight-meter hull diameter and seventy-meter length and the base model of Chuck Yeager's X-1 in 48th scale - which has the spindle shape so necessary to Verne's NAUTILUS.
    I am days away from painting this beauty!
    In my head I see a weathered black paintjob since in the book the only hull color I remember is black. BUT...
    Since the N spent a great deal of time on the surface wouldn't the color be somewhat lighter above the hull's centerline and especially above the waterline?
    Or should I go for a lighter stripe of color at the waterline as with modern subs?
    http://www.navy.forces.gc.ca/mspa_im....462.jpg
    I do think that the slight green algal sheen seen on the sub in the preceeding link would be a nice touch. But what about "the beard" that I remember seeing on a sub model years ago? Or barnacles? Anything to lend the model realism. :O
    Thanks!
    -Leelan Lampkins
    Leelan,
    I, too, am nearing the
    Leelan,
    I, too, am nearing the completion stage of my sub (Disney 1]http://www.subcommittee.com/forum/icon_sad.gif[/img]
    Basically, it was decided that if you were going for an authentic Victorian-era sub, the hull would be made from "black iron". This metal didn't rust unless it was scraped, so the hull would actually be in pretty good shape, except maybe for around the rivet heads and any damaged areas. Base color in this case would be a dark gray or black color, with a very light wash of rust.
    Dave Merriman's videos detail weathering an Ohio, including modelling the waterline, algae, barnicle, right down to the seagull droppings on the tail! Keep all of this in mind.
    My personal opinion was that Nemo would have done the majority of his travelling under the sea (hence the title of the book). My model will not show a waterline as a matter of personal preference. I'll be playing a lot with a dark brown basecoat and then rusting the finish from there in thin coats until I get the look that I'm going for.
    If you get the opportunity, pick up Dave's video. In it he superdetails the Ohio kit until the whole thing looks darn near real.
    My sub project can be viewed at the Nautilus Drydocks
    • lundberg
      • 55
      Hi,
      I painted/weathered my Nautilus in
      Hi,
      I painted/weathered my Nautilus in the following way
      1. Flat black spray from a can
      2. Several layers of RustAll
      3. a protection layer of clear flat spray
      I think RustAll is great, I've weathered my U-47 slightly with this as well
      www.rustall.com
      /Bjorn
      • wbnemo1
        • 37
        Here ya go ..... Granted
        Here ya go ..... Granted this was originally intended for painting a Disney version Nautilus but you could apply the same tehniques
        "Painting the Disney Nautilus" ...................one idea
        The Disney Nautilus: In my opinion, Captain Nemo would have never
        allowed his submarine to become an old worn out rust bucket.
        Therefore, he would have kept his boat in as good as condition as
        maintenance would have allowed him to on his excursions to and from
        Vulcania. To that end, for my own boat, and as a suggestion to
        everyone else, I would say with exception to the various lights and
        window viewports, paint the entire exterior of the boat with two or
        three thin coats of flat black. After this has been accomplished,
        strategically place around the ballast grates, scupper vents, various
        hinges, and other details, streaks and thin touches of rust; not a
        lot though.
        Once this has been done, seal the boat in one or two coats of flat
        clear acrylic, as this will suspend the rustic effect permanently.
        The next area of attention addresses two areas of the boat.
        The first and foremost are the forward ram, the bulb, and the
        rakers, commonly referred to as "teeth" of the Nautilus.
        Since these areas of the boat saw constant usage due to the
        ramming of the hulls of various warships, the rakers and ram's bulb
        wouldn't have too much rust on them, nor would they would they have
        much paint on them either. They would have mostly a shiny subcast of
        metal, streaked with rust and bright metallic edging. To achieve this
        effect, do the following. First, take and lightly paint each raker
        with a thin half and half coat of flat black. Allow it to set for a
        couple minutes, and then wipe it off with a soft rag.
        After this is done, make a mixture of battleship iron gray, medium
        tone, and drybrush silver metallic. Drybrush this over top the thin
        flat black coating along the very front edges and points of the
        rakers and ram bulb itself.
        Allow this to dry thoroughly, then blot, as per your own choice, the
        excess off, even smearing a bit to feather the edges to look like, or
        simulate, the scrapes, scratches, and abrasions sustained to the
        rakers and ram bulb during contact of the warship as the Nautilus
        passes through it's hull and keel.
        After this, apply a few light streaks of rust along the very
        bottom outside edges, and the tips here and there on the rakers and
        ram bulb itself, and you will have a realistically conditioned set of
        rakers and ram bulb on the front of the Nautilus to show the constant
        usage of this area.
        As you see, this is a very simple application.
        The second and foremost, one that everyone talks of is the ghostly
        glow of the submarine as seen at night - the look of a "Sea monster".
        Achieving this effect is not all that difficult following the
        directions outlined below.
        After the Nautilus has been entirely painted, and being sure that
        all your viewports and lights are masked, take in a Windex or hand
        squirt bottle of the type that can be adjusted for a fine mist spray,
        mix up half and half water and waterbased phosphorescent paint, or
        glow-in-the-dark paint. Once you have done this, lightly mist the
        entire boat from stem to stern.
        Allow this to dry and then in certain areas, underneath the side
        keels of the sub, here and there along the various grates and drain
        openings, details of the decking, and the like, put a slightly
        heavier spray in sections and allow to dry. I would refer to some of
        the various underwater stills of the filming miniature for this
        placement.
        The phosphorescent paint misting will give an almost algae-like
        appearance, looking similar to those deep sea dwelling species,
        barnacles, and other interesting specimens of marine life that find
        themselves hitching a ride upon their bodies.
        This carries the effect very well considering the notion that this
        is what the Nautilus was supposed to be anyway.
        Once the misting has dried thoroughly, coat the entire boat with
        flat acrylic clearcoat to seal in the phosphorus and allow it to dry
        completely.
        For the monster-glow effect, simply allow the Nautilus to sit in a
        well lit room, or run during daylight, and the phosphorescent paint
        will store up the luminescence it needs and once the sun has set,
        between the mixture of running lights of the nautilus and the
        phosphorescent glow of the paint which will last for several hours
        after dark, the Nautilus will truly be that ghostly monstrous sea
        serpent we all know and love.
        I hope you all will find these suggestions useful, whether you are
        building your boat for static display or for running radio controlled
        in the water - enjoy!!
        This article was originally written by:
        Robert T. Hughs
        Edited by William Babington
        Translated into English....... ha ha ha !..
        by Fred S Kuentz
        I'm a model maker not a typist ...William
        • captain nemo
          • 119
          Funny]http://www.subcommittee.com/forum/icon_biggrin.gif
          Seriously though, I've done
          Funny]http://www.subcommittee.com/forum/icon_biggrin.gif[/img]
          Seriously though, I've done a couple drawings of the boat, and I think she looks kinda neat with a two-tone paint job]http://www.subcommittee.com/forum/icon_razz.gif[/img]
          • michael
            • 15
            Just a note re Bob
            [color=#000000]Just a note re Bob the B's comment]
            • captain nemo
              • 119
              In Re]http://www.subcommittee.com/forum/icon_razz.gif
              In Re]http://www.subcommittee.com/forum/icon_razz.gif[/img]
              • wbnemo1
                • 37
                I honestly think at this
                I honestly think at this point,the Nautilus should be mostly blueish black with only hints of rust around strategic areas as mentioned in the arcticle i added above.....not a totally rusted boat the last scene in the film suggests this as well
                William
                • captain nemo
                  • 119
                  Yup. I started painting my
                  Yup. I started painting my NAUTILUS MINISUB rust oxide colored, but quit partly because I realized naysayers might label it "The Red Herring." I chose black for a lot of reasons, but long-story-short it just seems right.
                  Pat
                  • modelnut
                    • May 2003
                    • 432
                    Thanks mateys!
                    I will print out
                    Thanks mateys!
                    I will print out this thread and consider.
                    But at the moment I am leaning to the two-tone paint job with the waterline discoloration. The algal sheen below the waterline also appeals.
                    I will let you know how it goes.
                    -Leelan
                      I think the rusted look
                      I think the rusted look is the best, on a Disney Nautilus at any rate.
                      To my eye this most accurately reflects the surface shots of the boat, in the film.
                      Painting is the worst job for me, I hate it and would happily farm the job out elsewhere in exchange for other skills.
                      I do think any working Disney Nautilus needs good lighting.
                      For this I favour white LED's, which have come down in price dramatically over the past year or two.
                      Cheers
                      • captain nemo
                        • 119
                        One might wonder why Disney
                        One might wonder why Disney shows the NAUTILUS in different colors...
                        As one descends underwater, red is the first color lost from our sight; happens at about 20 feet I think (without checking the books). Since the NAUTILUS was large and much deeper than that, we wouldn't see it as rust-red underwater, and maybe that's why Disney makes it look black/blue when submerged.
                        Now, I started thinking how my sub would look at shallow depths, where the light is best for photography. (And this is something R/C modelers might want to consider, since their boats will also be photographed in the shallows.) I'd rather my boat looked like a larger sub deeper than 20 feet down, so I painted it black. For those wanting an R/C model NAUTILUS to look convincing when photographeed in shallow water, rust-colored aint the way to go.
                        But hey! It's all good! People should paint their subs whatever color makes them happy, right!?
                        Pat "it's what I do not who I knew" Regan
                        • modelnut
                          • May 2003
                          • 432
                          To clear things up a
                          To clear things up a bit, let me say that I am not building a Disney-type NAUTILUS. I am going for a Verne-type NAUTILUS.
                          Something like this]http://groups.msn.com/Modeler....oID=276[/url]
                          This was my NAUTILUS mark II. I abandoned it when I discovered an irreparable warp in the bow and stern.
                          Broke my heart it did.
                          I am nearing completion of my NAUTILUS mark III. This one is in 186th scale not 72nd. But there is no blasted warp anywhere (HOO-ray!) And as I said in an earlier post, this one is a kitbash instead of a 100% scratchbuild. So there are some differences to my original design owing to the use of the original kit peices. But it will still be a NAUTILUS.
                          For more inspiration visit]http://home.att.net/~karen.crisafulli/nautilus.html[/url]
                          And I am very thankful for everyone's suggestions on painting and the reasons behind them. You are an invaluable resource!
                          -Leelan
