1/72 Moebius Skipjack
    • 854
    Gents,
    Intending to use a home-built type cylinder set-up in this beast and was wondering if anyone might share how they did the saddle mounts for their cylinders??? I have some ideas for my build, but figured I'd ask about methods already in use. I know that whatever gets used has to be compatible with styrene adhesives.
    Thanks,
    Bill
    Re: 1/72 Moebius Skipjack
    I am currently building this Skipjack and another boat.
    I have purchased 1/4" thick by 2.5" wide sheet styrene plastic from McMaster-Carr.
    This is the same plastic the Skipjack is made of.
    I will be cutting half circles to fit inside the hull halves.
    Will be using styrene weld glue.
    Also from MCMaster-Carr
    I have 3.5" PVC solid rod to make end caps and in cylinder separators.
    And I have a 24" piece of polycarbonate tube for my cylinder. Will be cutting that to 21".
    I'm using information from another builder, Tim, who has a working boat.
    His boat can be seen HERE
    I have all the parted needed except the ballast water pump.
    3 pumps should be here any day. Only need one.
