magnetic switches
  • p webster
    • Apr 2012
    • 39
    magnetic switches
    Does anyone know of a supplier of magnetic reed switch and relay assemblies suitable for switching on the complete system of the sub (ie main battery and receiver battery.
    I am also looking at using 3 x 2v 8amp Cyclon batteries instead of the recommended 6v 12amp SLA battery. Except for the reduced running time can anyone see any other problems this could cause?
  • KevinMC
    • Sep 2005
    • 463
    Re: magnetic switches
    Hi,
    I might have something for you. Please check your PM
    KMc Designs
    • ober freak
      • Jan 2014
      • 114
      I use these Relays,
      1 in my Seawolf and 2 in parallel in my U47, with one reed contact per coil.
      Never had any problems with them.
      • johnredearth
        SubCommittee Vendor Member
        • Dec 2012
        • 47
        Get door switches off ebay. $1.50 each. Add a couple of relays and you have the perfect thing.
          Don Spielberger used to build and sell them. (Loyalhanna Dockyard...)
          • pedro gomez
            • Sep 2007
            • 91
            Engel modellbau has, and Norbert Bruggen Modellubootspezialitaten too.
              Reed switches can be found very inexpensively on ebay. You want a pair of normally open type often abbreviated to 'NO'.
              For a relay, you require a bistable unit. These can be a little trickier to find, but are available. You should aim to get one with voltage coils similar to your system voltage.
              If you want to switch very high currents you can have the relay contact(s) pick-up the gate of a P-channel Mosfet to switch the load, or perhaps switch the low side with an N-channel Mosfet (anyone tried that?). To switch the high side with an N-channel you would need a driver chip to raise the gate about 10 volts.
              • johnredearth
                • Dec 2012
                • 47
                For relays, check these out. Fabulous build quality, very very cheap
                http://www.ebay.com.au/itm/131164167875 ... 1497.l2649
                I have just installed one of these with a door switich on a surface boat!
                Cheers
                John
                • johnredearth
                  • Dec 2012
                  • 47
                  whoops I forgot I have something on this
                  John
                    Nice sub video John.
