Di-Electric Waterproofing Agent - Waterproofing Electronics
  • tennesseejim
    • 53
    I came across a product called AREOPLATE. The web site I found it on says that treating r/c radio components with it will make them "almost impervious" to damage cause by water. I was wondering if anyone had tried this product? Also I wondered if it would allow a person to use servo's without placing them in a wtc? The product can be found at]http://www.swampworks.com/Catalog-Radio%20Systems.html[/url]
    Thanks - Jim
  • no1_sonuk
    • Oct 2003
    • 11
    Well, bearing in mind that
    Well, bearing in mind that Swampworks usually deals with targets designed to be occasionally sunk, it'll probably work for submerged servos while they're not operating, but I wouldn't try it for prolonged submerged operation.
    • safrole
      • Aug 2003
      • 272
      Here's a nice article.
      http://www.ircwcc.org/manual/WATERPROOF/SERVOS.HTM
      BTW this
      The Home of the International Radio Control Warship Combat Club - dedicated to the battling of radio controlled model warships in a gentlemanly and good sportsman-like manner.
      BTW this warship club looks very interesting. An element of danger makes any hobby twice as fun.
      • fung pang
        • 91
        the AREOPLATE does works, I
        the AREOPLATE does works, I have seen a servo and a small trian run in a fish tank for 3 days( same servo? ) at the NY WRAM show, and I use it as a insurance.
        if it works, one may build a 100% all wet hull, been there, done that, came home with only the transmitter.
        * note, not with the AREOPLATE, is something call THE STUPH, I didn't have $$$ to try it again. *
        there for I try to over kill everything.
        fung pang
        • toneburst
          • Apr 2003
          • 63
          Besides the the option in
          Besides the the option in the article mentioned above, there is an option to use 'self-vulcanising' (hope this is the right expression) for the servo casing. Secondly if you mount the servo upside-down and fill the gearbox with something like silicone-grease, it will be waterproof untill about 6ft below.
          Cheap and easy solution.
          Jos.
            I have used "STUPH" for
            I have used "STUPH" for many years now. I keep a small brush bottle of it in my tool box. I coat all the metal parts of my boats before I run. I does a good job of protecting the parts from H2O, BUT! It will not protect them from heavily chlorinated pools. Don. Are you reading this, HINT HINT. (Sorry private joke) Dave.
