Boomin Beaver Helicopter tug!
    Well if that title did not get your attention nothing will.
    Well in my ultimate quest for the best rescue tug I have yet another master plan.
    (Cue the evil laughter)
    Although my Toot 14" logging tug worked out great and is extremely maneuverable.
    It kind of morphed into a pulling tug.
    I want something even smaller and more maneuverable.
    My answer is I hope, a 12" version of a 14' Bronc tug.
    That would make the scale 1/14.
    Odd scale but since I am building more for size and function it is not a problem for me.
    I have always wanted to build a Bronc as I think they are so homely they are cool!
    Now where most Bronc's are driven by a Z drive in the bow. (Front wheel drive)
    My plan is to use another drive system I have always wanted to try, a Voith eggbeater type.
    I acquired an old Graupner unit a few years ago for another project but I want to use this system in pace of the Z drive.
    I also will be using a bow thruster mounted in the stern.
    So I guess it will be a stern thruster.
    This should give helicopter like maneuverability.
    The Voith will move the tug just like the main rotor of a heli as the Voith is just like a swash plate in the way it works.
    The stern thruster will work just like a tail rotor.
    I will set up the radio the same way.
    In a normal Voith set up two drive units are used so the boat can spin.
    But using the stern thruster like a tail rotor should do the same thing.
    I am in the design stage now.
    I found a set of plans I like.
    I plan to construct the hull similar to how the real one is made, but where 1/4" sheet steel is used I will be substituting sheet fiberglass.
    Great stuff that I get from McMaster in different sizes and thicknesses.
    The tug is called the Boomin Beaver! I love it!
    Hopefully I have it all worked out. Time will tell. BD.
    Re: Boomin Beaver Helicopter tug!
    Here is a photo of the tug.
      Here are some photos.
      I designed and made a stern thruster.
      I also have a photo of the Voith drive.
      Then a photo of the drive parts sitting on a full sized plan of the tug. BD.
      • seahorse
        • Mar 2005
        • 320
        Hey BD, what's new with the Beav?
          Well!
          I have been sidetracked of late.
          I do have the parts cut out for the hull and need to get it assembled.
          How's this.
          It will be at the next fun run.
          Hopefully running but for show and tell at least. BD.
          • seahorse
            • Mar 2005
            • 320
            so many kits, so little time , just checking in to see how the Beav was doing! Looking forward to the show and tell !
              OK.
              I am actually doing some more work on the Beav.
              Here are the upper and lower hull parts made from 1/8" sheet fiberglass.
              They are held together with carbon tubes for alingment. Then the side skin made from 1/32" sheet fiberglass is wrapped around.
              This makes for a very easy to build and strong hull.
              • seahorse
                • Mar 2005
                • 320
                looking good Wally !
                  Tanks!
                  Here is a video of the Voith drive working on the bench.
                  • Larry Kuntz
                    • 524
                    One word fits that video of the Voith BD:
                      Larry running Li'l Chica
                        • 2349
                        Very cool Dave! I am amazed at the turning ability.
