Gents,
Need some advice/help. I have a robbe U47 with the accurate Armor conning tower, updated motors from ships n things, dual MCD speed controllers and the dual ships n things batteries. It is stock other than these items. My trouble is that when fully set up with both batteries it sinks, then if I take out one of the batteries it rolls over and to add insult it leaks at the rear seal.
Should I stuff some foam in the saddle tanks? I did try to remove 40mm of the lead weight as the instructions reccomend to lighten her so she would stay above water but this may have contributed the rolling problem.
Sad to say there is a big regatta this weekend and I was hoping to show off, there is this guy with a 1/48 scale Gearing Destroyer.....
What does the brain trust think?
Thanks in advance.
Charlie
Thanks in advance.
Charlie
