sub test
  • kurt250
    • Jul 2012
    • 30
    sub test
    just tested my alfa in my new test tank. before i put here in the water i ran the motor with no problems. the all of sudden the motor doesn't run eather out side the tank or in the tank. i have changes nothing in the propulsion end of the wtc. what could be wrong ? . batteries are charged both on the reciver and transmitter.kurt250
    Re: sub test
    I would do a check on all your wire connectors and check solder joints. Do you have a voltmeter? That would be a great tool to use to hunt down this issue!
    tom
    • kurt250
      • Jul 2012
      • 30
      Re: sub test
      tom, i think i fried the speed controller. i have been reading and found that they suggest a fuse between the batteries and the drive section. will check with v.o.m. meter. will install a fuse. kurt250
