I just ordered the new motor for Toot.
Here are the specs.
No. of Cells: 3 - 5 Li-Poly
8 - 14 NiCd/NiMH
Kv: 1000 RPM/V
Max Efficiency: 82%
Max Efficiency Current: 15 - 25A (>75%)
No Load Current: 2.0A @10V
Resistance: 0.059 ohms
Max Current: 37A for 60S
Max Watts: 550W
Weight: 132.5 g / 4.67 oz
Size: 35 mm x 47 mm
Shaft Diameter: 4mm
Poles: 14
Model Weight: 1000 - 2500 g / 35 - 88 oz
I will be running 14.8V.
I went as big as I could without loosing the user friendlyness of the tug.
I wanted the motor to fit in the mount I have now as well.
This should put some serious pulling power in my 14" tug.
BD.
Here are the specs.
8 - 14 NiCd/NiMH
Kv: 1000 RPM/V
Max Efficiency: 82%
Max Watts: 550W
Size: 35 mm x 47 mm
Shaft Diameter: 4mm
Poles: 14
BD.
