Re: Resurrecting the dead Gato project
Steve,
I've been following this thread with interest, and have a couple of observations.
It sounds like your making the whole thing way more complicated than it is in reality. For starts, almost all of the time your boat will be running just a few feet under the surface, maybe just a couple of feet, because in most situations you will want to be able to see your boat. Years ago I put an ADC in my boat, and found out that it was more trouble than it was worth. Jeff LaRue, is spot on when he suggests that a pitch controller is almost a must have item, but not the same with a depth controller.
I have always clung to the notion that a truly static diving boat elevates the probability of loosing it forever when (not if) there is a problem with the ballast system, the propulsion system (weed fouling, for example), or a loss of power. My boats have always been trimmed in such a way that even with the ballast tank full and the boat dead in the water, the top of the sail will still be just above the surface, even wilh a total loss of power, just like Jeff suggested. It takes a modest amount of forward movement to get under water, where the APC will take over the driving. Haven't lost a boat in almost thirty years.
SubTech makes really good and inexpensive seals for the drive shaft and control rods. You can get them at Mike's Subworks, or directly from SubTech , who are now in Malaysia, but were in the UK, and before that, the USA. Very well thought out and well made products.
Also, don't be too concerned that the drive shafts with counter rotating prop directions will be threaded both right and left. They almost always are threaded with standard threads, regardless of prop direction.
Listen to what Jeff advises...he's been one of the Yodas of this hobby since they invented water.
Steve,
