Which way do the props turn?
  • jack b
    • 45
    So I just want to be sure the props on a gato both turn out not inward Right?
    So why is that?
    JAck
    Re: Which way do the props turn?
    Twin prop boats turn better when the props rotate outwards rather than inwards. I'm sure someone better versed on propeller theory could explain why.
    • stuartl
      • Jan 2012
      • 24
      I'm intrigued about this, the only difference I can think of regarding the top side of the prop vs the bottom is that there's lower water pressure at the top. Otherwise 'outwards' vs 'inwards' seems interchangeable for a submerged prop...
      I'd love to hear more about this
      • stuartl
        • Jan 2012
        • 24
        I've just realised, after a quick google, that the effects of swirl, eddy currents etc on the hull are critical. I haven't yet found the answer, though, lots of differing opinions online.
          • 852
          US twin-screw boats turned outward. Port screw CCW, Starboard CW.
          B^)
          • robert f.
            • 161
            As a rule, propellors on multi-propellor[ u]seagoing[/u] vessels turnoutward when moving the ship forward. Having the propellors turn outward prevents the hydrodynamic forces created by them from reinforcing each other, which might cause damage to the ship and/or the props (cavitation for example).
            But why should they turn in opposite directions? Well, a turning propellor, as we all know, causes momentum, affecting the ship 's course unless this is corrected with the rudder. (Sailing a one-propped model backwards shows this effect most clearly).
            This effect would be much stronger and possibly even impossible to correct with all propellors turning in the same direction. With the propellors turning in opposite directions, they will compensate each other´s momentum and the ship will keep a straight(er) course.
            On non-seagoing multi-propped vessels, the propellors still turn in opposite directions, but this time they turn inward when moving the vessel forward. I'm not sure, but I'm guessing this has to do with the different hydrodynamic conditions of shallower and/or sweet water.
            Robert
            • stuartl
              • Jan 2012
              • 24
              Do you know why outwards rather than inwards? The only difference I can think of is the compression version expansion effect of the hollow between the props and the hull...
