Hey guys!
I'm currently scratchbuilding a peristaltic pump for use as the main pump for a central ballast tank. In the process of selecting an appropriate motor and gearbox, I've come across motor/gearbox combinations rated at 60, 70 and 100 RPMs. For those who use these pumps in subs, which RPM rating would be best suited to pump water at a moderately fast speed? I know that a lower RPM rating will yield a higher torque, which is desirable in a pump of this type since the rollers are pressed against the rubber tubing of the pump and must rotate. Will the 60 RPM gearbox be too slow to pump water? Should I go with the 100 RPM one to be safe even though the torque might be lower?
Thanks in advance!
Nate
Thanks in advance!
Nate
