Upgrading a Thor Design's 637
  • tommydeen
    • 327
    Re: Upgrading a Thor Design's 637
    no worries Tim..I know all about duty.. its all good
    • subicman
      • Dec 2007
      • 217
      Tom,
      Here you go, I took a crap ton of pictures of the towed array tube and fairing. Hope it helps, Getting ready for our Subron 4 meeting today.
      One word about the towed array fairing casting. The alumilte continued to cure and shrink, at the beginning of this year, I had to re-attach the fairing and pin it into place, hence some of the primer spots on the casting. My plan is to repaint topside this winter
      • subicman
        • Dec 2007
        • 217
        Opps,
        Forgot the ones with the ruler in the pic. I only have a steel one so thery are not the best.
        • subicman
          • Dec 2007
          • 217
          Continueing with the mast construction. I cut pieces out and placed them up against the scale drawings to get the lengths and curves set right. I took a piece of brass tubing (can't seem to find the size I used in my notes) and squashed it into an oval with a vise to form the antenna portion. I also pulled my scope barrel out of the resin mast. For the BLA-4 i turned to my trusty acient Craftsman metal lathe and turned a new antenna for that. I soldered everything together very carefully, when working with stuff this small, a micro torch is a MUST!
            • 1479
            Tim,
            Yes! When you get those drawings done send them over and I will get to work doing what I can. I should have everything set up in the new shop by late spring and my health should be back to the point that I can operate the machinery. I really miss that old Sturgeon of mine. I wish I could remember who I sold my old boat to. I would buy it back. It was the one I had at the 1994 & 1995 Regatta. What a stupid move to sell that boat!!!
            • tommydeen
              • 327
              Wow thanks alot Tim the pics help!!!!!
              • Rogue Sub
                • Jul 2006
                • 1724
                Tim- BUTCHER!!
                Thor- I thought I was your favorite Nuke?
                  • 1479
                  oh, boy......
                    • 848
                    Kevin,
                    You are, dork! Tim is a non-nuke twigget!!!!! Formerly a two-wire electrician. Sheeeshh!! How quickly they forget!!
                    B^)
                    MMCS(SS) USN (Ret.)
                    World's greatest living Submarine Auxiliaryman
                    and friend to small furry creatures
                    • Rogue Sub
                      • Jul 2006
                      • 1724
                      Bill are you a member of the furies?
                      • Rogue Sub
                        • Jul 2006
                        • 1724
                        Just so there are no misunderstandings....
                          • 848
                          Kevin,
                          No. They're not small, nor furry enough!
                          B^)
                          • Rogue Sub
                            • Jul 2006
                            • 1724
                            #28
                            I am not convinced
                              ....nor pink enough?
                              • subicman
                                • Dec 2007
                                • 217
                                #30
                                jeez, go out to sea for a week and you guys hijack my thread for FURRIES?!?!?!?!
