1/96 SSBN 626 Daniel Webster w/ bow planes
  • Rogue Sub
    • 1724
    I have intended on building this model for some time. Partially because it is one of the nuke training ships (MTS 626) and because I know a ship mate that once sailed on it. The boat also fits into my goal of having all the US boomer classes in 1/96 (gonna took great on the wall).
    I am starting with a SSY Lafayette class hull that I acquired about 3yrs ago. Time has not been kind to this hull as it has begun to bow due to its thin layup. For this reason I am making all the support cradles out of 1/4" G10. There will 6 of them total, not including the shaft support which will be strong as well.
    I will also be doing this boat with the bow plane set up that was used for awhile. It was initially installed to help eliminate proposing while at shallow depths. This is an issue for even the ohios. Anyone who has served can tell you how loud a bang the sail planes make when the slap back into the water. If you get the whole missile deck out of the water we generally issue the dive officer of the watch a set of pilots wings. Now from what I have been told by people who were on the boat with the planes on, they worked great. On the other hand they killed the boats top speed due to all the extra drag. For this reason they were removed and a more standard set up installed.
    Well here are some photos of the progress. The z cut has been done, some minor filling, saddles are cut and starting to be installed, and the initial z cut has been changed and hull halves re attached.
    Initial hole cuts for the MCS saddles
    Sail permanently fiberglassed on
    Seem fill from the z cut
    Fiberglassing the sail on
    stern planes install
    ballast flood holes cut
    hull fix
    hull fix
    cutting out the saddles with diamond wheel
    rough saddle before final sanding and fit
    All the saddles test fit in
    Fabricating the shaft support
    Epoxy of the fwd MCS battery compartment saddle
    test fit of the stern shaft support
  • pirate
    • 849
    Re: 1/96 SSBN 626 Daniel Webster w/ bow planes
    Go Kevin. Go Kevin.
    • Rogue Sub
      • 1724
      LOL where am I going
      Pete make a 1/96 GW! It would handle awesome.
      • Rogue Sub
        • 1724
        Finished all the flood holes, sanded the bow after using nitro stan, drilled the rudders, and added some alignment pieces
        That going to be it for a bit as I leave from Florida to New York. Ill be living in a hotel for the next 2 weeks so, I wouldnt expect to much going on
        • boss subfixer
          • Aug 2004
          • 656
          What do you mean, a hotel room didn't stop you before.
          • Rogue Sub
            • 1724
            True but I don't have my tools this time.
