I've been away from this forum for quite a long time.. Have a question about Evercoat fillers. I have never used them before. I recall, Steve Neill and David Merriman use this stuff on their sub models. Aren't the Evercoat products intended for use on automotive metal body panels? I know the above mentioned guys use them on fiberglass hulls.
Which of the Evercoat products would be best for fillets and general filling of gaps when bonding urethane resin parts to an ABS vacuum-formed plastic hull? Also for fillets between metal and ABS plastic? In specific, for use filling gaps between the urethane resin lower tail and the ABS hull on the 32P XXIII model. And for same use to blend the metal, ballast weights to the bottom of the ABS hull by creating a fillet around the perimeter of the rectangular weights.
Evercoat "Easy Sand" or "Metal Glaze"? Or one of their other products? I am considering the "Easy Sand" 24oz bottle in particular, but would like to hear some opinions.
