Paint for submarine
  • subbug1
    • Apr 2010
    • 8
    Paint for submarine
    Can someone tell me what is the best brand and type of spray paint to use on a sub hulls plastic and fiberglass?
    Re: Paint for submarine
    Depends where you're painting, and what material the hull is made from (GRP is very different to say polystyrene).
    Acrylics are pretty safe to use on either material. Cellulose finishes will melt polystyrene hulls unless they've been hit with a suitable primer first.
    I would recommend using a good primer that is designed for plastics, this promotes good adhesion.
    • fgroza
      • Jun 2005
      • 168
      I've used Krylon ruddy brown and semi flat and flat black with good results. Another paint I use is Floquil railroad paint. It is a little pricey, but they have any color you need.
      Frank
      • subicman
        • Dec 2007
        • 217
        Floquil is my choice, weathered black looks like scale black on a sub.
        • tabledancer
          • Feb 2005
          • 573
          I thought that they quit making Floquil because it was so dangerous to inhale the vapors and I heard that California banned its use.
          TD
            I haven't heard anything about that, but I just got a new batch of Floquil paints without a problem. They're awesome.
              Mike....Its California....! They would ban the breathing of air if they could!
              Floquil is great stuff.
              • the dark knight
                • Feb 2010
                • 164
                if you havent noticed, everything is know to cause cancer in california. weather its brake clean or paint! but if your not in CA, its ok! i keed, i keed.
                • subicman
                  • Dec 2007
                  • 217
                  Checks with chart for California, figures they would ban acrylic paints.
                  • bill rogers
                    • Sep 2003
                    • 90
                    Floquil brand paints were still sold here in California last year when I built my USS Will Rogers.
                    • tabledancer
                      • Feb 2005
                      • 573
                      Well see how you guys are,now you are going to make me go out and buy that nasty California banned great paint again,so that I can get a buzz on while I`m painting my XXI.I used Foquil years ago when I was model railroading,not only would you get a great buzz on but you would also get a great paint job too.I have been using Model Masters paints for about 10 years now and I am getting bored with all that so I think I go back to the Floquil,they have a wider and better choice of colors.Even though Testers owns both of them now.
                      TD
                      • fgroza
                        • Jun 2005
                        • 168
                        Mike,
                        Floquil changed hands a few years ago snd is now under the Testors label. They also changed the formula on the Floquil paints--- they were a laquer base and now are of the enamel variety. If you have some old-- look at the label, the new type is different-- you may not be able to mix them together due to different base materials. The old type you could use laquer thinner - new you must use the all purpose thinner they sell, $10 a pint!!!!! I used Floquil on my Type VII and it worked great. Just remember to seal the final finish with either Dullcoat or Floquil flat finish. This will seal your weathering and decals you may have put on the sub.
                        Frank
                        • tabledancer
                          • Feb 2005
                          • 573
                          Yes that was the good old days,you could really get a buzz from that old Floquil.I still have a lot of Armor Yellow and Harbor Mist Grey laying around.Here is something to really work your brain over,try figuring out how much you would pay for a gallon of any brand of paint that you use for your hobby if you had to pay hobby shop prices per ounce of paint at the local auto parts store or body shop supply.It will stagger you.Now you know why you are between a rock and a hard place!!
                          TD
