New Galathée Sub - ADX Models
  • solo
    • Apr 2009
    • 32
    Hello Guys, and sorry for my English
    It's always an emotional moment, opening a big box containing a model kit of submarine RC
    But this time the symbolic dimension is there because it is the first model sold by Aurélien DOUX since the end of the company Lecma!
    We were fortunate to discover a few days ago the range of our 2011 National craftsman and now includes a model as iconic as the Galatée
    New topic devoted to assembly of the first submarine ADX Galatée, "a first then, is only ScaleSub!
    The purpose of this subject is also to demonstrate that the Galatée is a model that can be mounted on a corner office with minimal equipment and in a relatively short time.
    We'll see, by spending 1 hour a day to assemble the submarine, how long it will take to finish it
    The contents of the box is always full, in fact, pump, motor, battery, cables and other linkages are present. The manual is detailed and makes assembly step of the model, note in passing that it is now stamped with the logo ADX Models
    And of course the beautiful CNC cut plate
    Well it was too tempting, so tonight I set up the main rack. Children's play and above all a pleasure to assemble, it must be said that the ultra fine cutting CNC provides exceptional precision.
    Parts are detached from the main plate, they are deburred and sanded.
    One hour for this first part, cutting parts, tightening the screws
    See you
    Re: New Galathée Sub - ADX Models
    Very nice kit. I like the Galathee.
    But I had not noticed Lecma is gone...
    Looking forward to your build !
      • solo
        • Apr 2009
        • 32
        Hi Matt, Hi Ronald,
        Lecma society no longer exists in almost a year now and it ADX Models (Aurélien Doux) which incorporates the production and marketing models for 1/100 Typhon and Galathée.
        Regards
        • solo
          • Apr 2009
          • 32
          Hi,
          1 day/1 hour, here after making the Galathée from 2 hours devoted to assembly of the submarine
          Begin the back by cutting and sanding the PVC cones.
          Then it prepares the cap back on fixing the stern tube.
          The cone is now set to end cap to form the rear of the model.
          • solo
            • Apr 2009
            • 32
            Hello,
            Here is the result of the third hour devoted to Galatea 2
            The work today is on the tail cone and liaison with the rack.
            • solo
              • Apr 2009
              • 32
              Already 4 hours of construction
              The assembly step by step of Galathée pressure ballast .
              Soon, it will be time to address the electronic model
              • solo
                • Apr 2009
                • 32
                Hello
                It's been long time I have not worked on the Galathée but after 2 hours of construction, the electronics are mounted in the submarine
                • solo
                  • Apr 2009
                  • 32
                  Hi,
                  After 2 hours and fews pictures
                  Next step testing in the pool
                  • Wheelerdealer
                    • 315
                    Looks great. Are you going to be adding light and bit to it? Also what type of seal is used for the prop shaft?
                    • solo
                      • Apr 2009
                      • 32
                      thank you Ramesh, yes I'll put lights on the submarine.
                      For the joint, it's a (in french) "joint spi"
                        The Galathee uses a simmering (oil seal) pressed into the plastic endcap.
                        • solo
                          • Apr 2009
                          • 32
                          Hi
                          Thanks Subculture
                          Ramesh, here are the electrical contacts for the lights.
                          • solo
                            • Apr 2009
                            • 32
                            Houla... it was very long this time
                            But this afternoon was right to spend three hours on the Galatea and mount all the electronics. The radio is in place and everything is functional, remains to dive into the tub to check the tightness of the model.
                            We'll see tomorrow
                            In the meantime, some pictures ...
                            • solo
                              • Apr 2009
                              • 32
                              Hello guys
                              Following assembly of the hull...
