As reported on in the SCR of December 2009 in a article by Tim Smalley about the goings on in subron 6, mention was made about Matt Mungers new WTC. I did a little digging on it hoping to find that the manfg. made different sizes. Unfortunately OMS makes only one size and that is 8.19" overall, 2" I.D. , 2.38" O.D.
Water tight cyl.
Tags: None
Re: Water tight cyl.
You could also use it as a wtc for 540 size motors. You might even be able to get a 700 in it. If its too long you could cut out however much you need out of the middle(preserving the threaded ends) and epoxy it back together. Im sure that they make a purpose built adhesive or cohesive for the job.
