Matt Thor Alfa Kit
  • jeffg
    • 28
    Matt Thor Alfa Kit
    Any hints on where to get a new prop, preferably brass?
    Re: Matt Thor Alfa Kit
    Prop shop UK
      Prop shop will cast props in silicone bronze (which looks like brass but is a heck of a lot tougher), stainless steel or aluminium.
      Fantastic quality.
      Website http://www.prop-shop.co.uk/
        The great thing about the Prop Shop UK is that they already carry the 1/72nd scale Alfa prop in brass.
        • jeffg
          • 28
          Thanks Matt
          JG
            Not wishing to be pedantic, but Prop shop props are not cast in brass, they're cast in silicone bronze.
            The materials look the similar, but there is a huge difference in strength and rigidity between the two, not to mention that silicone bronze is a swine to machine and work. So when you order your prop, make sure you specify what size hole and thread you want it tapped out to (Simon will usually ask you this when you make the order).
              You are quite correct, Andy. My oversight.
              • roedj
                • Apr 2008
                • 162
                Not wishing to be "really" pedantic but they're cast in silicon brass not silicone brass.
                Dan
                  Oh very well. BTW it's bronze not brass.
                  • roedj
                    • Apr 2008
                    • 162
                    You, Sir, are absolutely correct.
                    As you read this I am throwing myself on my sword. (But a good 12 hour epoxy will close up the leak)
                    Dan
