Deboer 57 inch Seaview
  • steveneill
    • Jul 2009
    • 716
    Re: Deboer 57 inch Seaview
    Jeff thanks a bunch! When will we ever get together and runs some boats? You are in my town of sorts a rare thing in LA. Lets do it soon. You got to try Hansen Dam. The water is clear and you can see to the bottom. We have a great dock to launch from too.
    Of course if you need help on the Seaview let me know. I've been able to trim them so they don't need lots of non-scale mods. You can use my pool if you like too.
    www.steveneillsgarage.com
    • tomwittstock
      • Jan 2004
      • 57
      I like the last part of the video showing the conning towers lights. I'm sure I'll be having issues once I get started on my boat Steve. Experince is the best teacher they say....I don't think OTW 3.5 inch will be large enough to handle my 80" Seaview.
      Later
      • steveneill
        • Jul 2009
        • 716
        Sure won't. But the 4 inch might since it works well in the 1/32nd VIIC and that's 81 inches long.
        If you need any help let me know.
        • steveneill
          • Jul 2009
          • 716
          BTW I placed stators in the nacelles the vector the water flow up. This helped a great deal in over coming the nose down effect. I'll get a picture tomorrow to post. This was originally a David Merriman concept and a good one too. It saved my fanny on this one.
            I think you'd need a stretched version of the Type VII OTW module if you want to get a very high waterline on the Seaview.
              • 947
              Steve,
              You're right: we're long overdue to get together. We'll make it happen. Soon, I hope. Been meaning to try Dam waters for ages.
              Will definitely be wanting advice -- if not full-on assistance (eventually) -- with Seaview. Love the engine nacelle stator idea. Believe I have most if not all of the parts and equipment necessary, though I realize I'm probably going to have to ditch (sell) the D&E WTC I already have for her and replace it with a larger version in order to achieve that high freeboard look. Or maybe it can just be extended (?). Also want to somehow create correct-looking pumpjet intake gills/louvers in the proper scale on the nacelles. I'd far rather open unseen sections along the keel for needed water flow than mess with the scale look back aft. We'll talk.
              Meantime, back to my Nautilus...
              Thanks!
              JeffP
              • steveneill
                • Jul 2009
                • 716
                Andy this thing will just roll over if you get it much higher. It's so flat bottomed. Its a movie model. Between the sloping bow and the shallow draft it's a trimming nightmare. All they did was drag it with cables so it could sit out of the water at the ridiculous height. But still the longer ballast tank may be of help on it. Not sure really.
                Jeff I tried to open her up from the inside to the nacelles. And the intakes were quite large. It didn't work and I ended up cutting two large holes on the under side of the nacelles and that worked. The scale louvers are open to sea on this one but were not affective at all. The pump jet works great on mine and is centrally located at the keel. Just a big oval.
                • junglelord
                  • Jan 2009
                  • 347
                  Could you not scale up a Big Dave Mobieus Seaview approach to this model Steve, vs the way you conquared this one?
                  I have been wondering if I could take that approach with my Deboer when I get it.
                  Any thoughts?
                  • steveneill
                    • Jul 2009
                    • 716
                    I guess with the PJ and all. Not sure it would make much difference. You will still be hanging your tail at 35 degrees at full stop underwater no matter what you do. Just don't ever stop the boat until on the surface.
                      I was referring to fitting the Type VII module in an eight footer, Steve.
                      • steveneill
                        • Jul 2009
                        • 716
                        Ya I know Andy. I think it would work fine if it works on the VIIC. Just my opinion. Maybe not. But it doesn't take much to submerge this boat. Less than half the ballast tank volume and down she goes.
                        Thanks,
                        • junglelord
                          • Jan 2009
                          • 347
                          Type VII module
                          Who makes that WTC?
                          • steveneill
                            • Jul 2009
                            • 716
                            #28
                            OTW
                              • 947
                              #29
                              Hey Steve,
                              Just tried to e-mail you and it bounced. Guess I need a more current address. Got one for me?
                              Thanks,
                              JeffP
                                I was going by Alan Warehand's experience with this boat, he told me he needed a volume of about 3 litres, and AFAIK the OTW Type VII module is about half that, although I'm sure Bob could answer that much better than I.
                                It shouldn't be a problem to make the module bigger, they're built to order, so you can tweak things a bit.
