Bagpumper - to seal or not?
  • subkraft
    • Jan 2009
    • 76
    Hi,
    This is a pic of my nearly complete slightly modified Arkmodel Song wtc:
    The reversing pump simply pumps water in and out of the bag thru the solenoid valve. The bag is suspended in a tube within a tube. The manufacturer shows this inner tube well sealed up around all joints.
    I like to be able to take things apart....is it important that the tube within the tube be airtight? The only advantage I can see that it would contain the change in internal pressure as the bag inflates...
    Any bits of wisdom appreciated.
    Model is getting closer to finished][/url]
    Depending on the pressure that
    Depending on the pressure that is developed it could play havoc on your output seals.
    I have seen that type of seal blow up like a balloon from too much pressure inside.
    Maybe that is why they do it.
    Give it a try on the bench and see. You can always goop it up after.
    Or just ask Arkmodel. BD.
