reception gone after 1 foot of depth???
  • maverick pro
    • Jul 2009
    • 22
    hey guys...im lost here, ive routed my antenna out side the wtc and out side the sub and still cant get past a foot of water with out complete loss of control. it happens with motor running and without.
    the setup...
    7.4 volt 2 cell lipo
    futaba skymaster radio
    futaba fm 75 mhz 8 channel
    2 micro servos
    apc
    viper esc
    graupner 280 motor with 3 capaciters
  • skip asay
    • 247
    A couple of questions:
    1. Is
    1. Is this fresh water or swimming pool?
    2. Is the end of the antenna waterproofed?
    Skip Asay
    • maverick pro
      • Jul 2009
      • 22
      hi...its a pool with no
      hi...its a pool with no chemicals at the moment. starting to turn green
      yes i did make sure the antenna was waterproofed.
      thanks...mike
      • petn7
        • Jun 2003
        • 616
        What frequency are you using
        What frequency are you using again?
        I am not aware of any 75 MHz frequency on Channel 8. I believe Channel 8 is on the 50 MHz band. Or perhaps you are saying your receiver has 8 channels?
        • ramius-ii
          • Apr 2003
          • 393
          Just a few questions. Which
          Just a few questions. Which make and model of transmitter are you using and which receiver? Is it possible you have a mismatch between the transmitter and receiver such as having the transmitter that is PCM and the receiver is set to PPM? Do you know if the transmitter is putting out full power? When you routed the antenna, did you accidently cross a metal surface? Is the antenna still at full lenght, that is it has not been cut or have any cuts in it? Have you checked that the receiver has the full 4.5 volts and the voltage does not sag (go down) when in use?
          Best, Ed
          • maverick pro
            • Jul 2009
            • 22
            hey guys...not its a 8
            hey guys...not its a 8 channel reciver on 75 mhz and channel 87. the radio and reciver is futaba fm not pcm. the antenna has never been cut and is at its full length. the radio tray is aluminum the reciver sits on and the battery. could that possibly be the problem?
            late last night i routed the esc away from the reciver. im going to test run it today and see what happens.
            thanks again...mike
            • ramius-ii
              • Apr 2003
              • 393
              Hi Mike, I was thinking
              Hi Mike, I was thinking more of how the receiver could be de-sensitized such as running on a low voltage or maybe the receivers front end became blown from over heating or by too strong a signal. The other posibilities are the transmitter is putting out low power, there is a problem with the transmitters antenna. FM is a type of transmitter (Frequency Modulation) and there are two common types of modulation of an FM signal, PCM (Pulse Code Modulation) and PPM (Pulse Position Modulation). There is typically a switch or jumper on the receiver to select the "Mode". Usually when the servos or motors are operating they will draw so much power the receiver ends up not having enough voltage to operate correctly. Simple, small voltmeters cost about $10.00 and are very useful.
              Best, Ed
              • maverick pro
                • Jul 2009
                • 22
                Best, Ed
                i always thought that if running ppm there would be no way to control a reciver that was pcm. even if i get in the pool with no motor running and set it at the bottom of the pool i have no control what so ever. i never thought that the micro servos and the little 280 motor would pull the 7.4 volt lipo down that fare. i will like you said get a voltage meter to check and see.
                thanks again...mike
                • maverick pro
                  • Jul 2009
                  • 22
                  Re: TDS
                  If the pool has not been drained for several years and replenished with fresh water the total dissolved solids could be higher than salt water.Swimming pools normal tds levels are usually below 700 ppm.I have seen some public pools higher than 2500ppm which means the facility should be closed by the health dept.Pool water sanitizers will not oxidize and sanitize the water when the tds goes too high and the conductivity of the suspended solids are too much for radio signals to penetrate.
                  i will try and find a better water sorce and see what happens. the problem is most water around here is salt or brakish. your right the pool has not been drained then filled fresh in a long time.
                  thanks again...mike
                    Mike,
                    I don't think this has
                    Mike,
                    I don't think this has been asked.....
                    How far away can you move from the boat when it's not in the water and still have control?
                    • ramius-ii
                      • Apr 2003
                      • 393
                      Normally you are correct the
                      Normally you are correct the servos and motors when running will not cause a voltage drop. However, the startup current draw can be quit high. Two other thoughts, it could be that either the power or ground connections for the receiver could be poor. You may wish to ground the receivers tray. Antennas actually have two sided and grounding the tray may allow the tray to act as the second side of the antenna.
                      Best, Ed
                      • maverick pro
                        • Jul 2009
                        • 22
                        Mike,
                        Mike,
                        so fare i havent don a range check. it works on the serface no problem. will try it tommaro and let you know what happens. im thinking at least 50 paces and it should still work antenna down???
                        thanks again...mike
                        • maverick pro
                          • Jul 2009
                          • 22
                          Best, Ed
                          never thought of that...if the problem continues after a reciver change i will give it a try.
                          thanks again...mike
                          • steveneill
                            • Jul 2009
                            • 716
                            Re: TDS
                            Correct!! This is what happened to my pool after years of not changing the water. Once the water was changed I could dive straight to the bottom at 8 ft with no problems. Try to find a fresh water pond to run it in a save yourself the trouble. If you have good reception at a local lake, then you need to change your pool water.
                            Steve
                            www.steveneillsgarage.com
                            • maverick pro
                              • Jul 2009
                              • 22
                              hey steve...will do. im going
                              hey steve...will do. im going to have the same problem with brakish to right?
                              mike
