Help leaking water
  • xxl
    • Jul 2008
    • 79
    Help leaking water
    whats the best way to find a leak in a wtc
    • 684
    Remove sensitive electronics
    Fill with paper
    Fill with paper towels and lead weights so it will stay submerged
    Put it in your test tank
    Watch for bubbles
    If the bubbles are inconclusive, check the paper towels for the wet spot.
    • skip asay
      • 247
      Drill a 1/8" hole in
      Drill a 1/8" hole in the pressure hull/wtc and glue a piece of brass tubing into this hole. Attach one end of a piece of hose to this brass tube and the other end in your mouth. Submerge the pressure hull/wtc and then blow. Look for bubbles. Fix leak. But DON'T FORGET to plug the brass tube BEFORE the boat goes back in the water!
      Skip Asay
      • Rogue Sub
        • 1724
        I use skips method. Its
        I use skips method. Its simple and WORKS.
        • davinci
          • Jul 2009
          • 68
          On my larger WTCs that
          On my larger WTCs that have O-ring-seal type end-caps, I tap a hole in end-cap and install a Schrader-valve (tire-valve). Pressurize it a little, check for bubbles. Going to higher pressure will remove the end-cap and it's attached assembly, which is handy if it's very tight.
          Schrader-valve is at very bottom of this pic, with chrome cap on it.
          Click Pic:
          • carcharadon
            • 301
            If it holds a vacuum
            If it holds a vacuum for an extended period it’s sealed. A vacuum better approximates the real life situation more so than pressure. But bubbles are easy to spot.
            • ramius-ii
              • 393
              One other mix of techniques
              One other mix of techniques is to use a fish tank air pump feeding a brass tube installed in the WTC. Then a mixture of soap and water "painted" on the outside of the WTC. Much like when you look for a natural gas leak. The advantage of the fish tank air pump is that you will not "colapse a lung" if it takes time to find the leak.
              Best, Ed
              • skip asay
                • 247
                Note that none of the
                Note that none of the methods described above is 100% fool proof. I recall many years ago testing my boat in the test tank, getting zero bubbles, and then finding a couple of cups of water inside once I got home. Proceeded to go back to the test tank only to find zero bubbles. Time to start pulling the hair out! To cut to the chase, it turns out that a silicone fillet inside one of the bulkheads must have been applied over epoxy which hadn't been prepared properly and this resulted in a one way valve. High internal pressure would seal it off while high external pressure would open it up. Since I wasn't using plex/lexan lids at the time, it took some doing to find that one!
                Skip Asay
                • junglelord
                  • Jan 2009
                  • 347
                  Very informative thread. Thanks for
                  Very informative thread. Thanks for all the replies.
                  • tsenecal
                    I also had a situation
                    I also had a situation where the temperature of the bathtub was 15 degrees higher than the temperature in the pond.
                    the difference caused enough shrinkage of the cast endcap to allow a tiny dribble of water to get past the o-ring when it was in the pond, but not in the bathtub.
                    I now include a 30 minute sit in the fridge for my WTC prior to it going in the bathtub for testing.
                    • steveneill
                      • Jul 2009
                      • 716
                      What I do is use
                      What I do is use the tire valve in the end cap. Attach a filler to it and blow a bit of pressure through the tubing connected to the filler and release.
                      Then using some dish soap in water solution I coat the surfaces that can leak. End caps, seals, etc. The slightest leak will produce and nice foam of bubbles.
                      I have found leaks this way when the submerging method did not or it was so small I failed to see it. And you never have to submerge it in water. All on the bench.
                      www.steveneillsgarage.com
                        Test for leaks
                        RCABS equipped models can easily be tested for leaks using the aforementioned pressure or vacuum methods. For RCABS WTC's there is already a brass tube through an end cap going from the air pump to the external bladder. Remove the bladder hose and the air pump hose from each end of the brass tube, reinsert the end cap and blow into the brass tube through an externally attached rubber hose as described in the above posts. Pinch the rubber hose, and look for soap bubbles or underwater bubbles depending on your chosen technique. That is a pressure test.
                        For a vacuum test, keep the fully assembled WTC and attached bladder underwater (or slather the end cap/cylinder sealed areas and penetrations with the soapy solution) and signal the pump to inflate the bladder, causing a partial vacuum in the WTC. Look closely for either water or soap bubble penetration into the WTC. That would be the vacuum test.
