Hi, I have a micro air pump that I want to use as a low pressure blower.
As you can see it has no intake fittings just the output. With your RCABS-R I noted that you're using a larger air pumps with similar layout. How did you modify the pump to such air out of the bladder?
I was thinking of fabricating a small chamber with an intake fitting which I can screw over the intake valves ( those 2 spikes next to the output pipe are the ends of the rubber valves).
