British T-class Project
  • davinci
    • Jul 2009
    • 68
    , try foam high in
    , try foam high in the boat
    Yes, that's what I did, by adding some inside ballast-chamber.
    As I said, there's no other place left, even in the cover which fits very tightly over WTC assemblies.
      What sort of battery is
      What sort of battery is it. Is it a lead acid block?
      A cylinder of batteries running under the wtc in the keel would make things much more stable
      • davinci
        • Jul 2009
        • 68
        It's a thin flat SLA that lays on bottom of hull, on top of lead weight. Only about 1" thick.
        Changing to this type battery helped greatly but still not enough.
        See pics][/url]
        • davinci
          • Jul 2009
          • 68
          Here's a pic showing shape
          Here's a pic showing shape of keel, taken during construction before weights were added.
          Click pic to enlarge:
            Okay. I'd advise you find
            Okay. I'd advise you find another home for the lead acid pack.
            Remove the lead weights from the keel, make up a 12 volt (10 cells) pack of either sub c or AA NimH batteries. Wrap them in heatshrink and cap off the ends with silicone sealant to make the assembly waterproof. This will lie in the keel. Now get some sheet lead and place that in the hull under the cylinder.
            I reckon that should sort it,the NimH's will also give you more capacity. If it doesn't you are really looking at a separate keel or removing top weight somehow.
              • 1479
              Is there foam underneath the
              Is there foam underneath the deck on the top half of the sub? I didn't see any pics of that.
              • davinci
                • Jul 2009
                • 68
                LOL
                I might as well get another hull and Start over again to do that.
                No Thanks!
                Like I said it looks like the latest foam addition is going to make it usable.
                I need to do more testing in deeper water to determine how much of a Real submarine I'll have tho. I've been testing in hot-tub.
                Hey, a surface cruiser is okay too.
                It's been a learning experience. The main thing I learned was how easy it is to make this hull design be Top-heavy. Since it was when I got it.
                • davinci
                  • Jul 2009
                  • 68
                  Yes, a little in the front of cover. Just not much space under there.
                  Plus it needs good ventilation for air and water, thru holes in cover.
                  Foam in cover only effects submerged balance tho, not surfaced balance, which is where it's main problem is.
                    if I understand you correctly
                    if I understand you correctly your boat rolls side-to-side and to battle that
                    you added lead and foam and now when submerging it stands on it's nose.
                    right ?
                    if so, you can try adding weight low in the tail instead of foam high in the nose to get the boat level. this will not aggravate the roll, just the waterline.
                      • 1479
                      Always start with your submerged
                      Always start with your submerged trim first. Stick thin strips of foam to the sides of the top . This will allow the air to vent. That deck is very narrow, it will not need much space for the air to vent. When and only when you have the submerged trim fixed do you start to mess with surface trim. If you are losing control of the boat in a dive, you must fix this first. You must have control of the boat first, before you start tweaking it. As Paul Crozier said, foam floatation as high as possible, weight as low as possible. From what I have seen in your pics, you have set yourself up for a rollover by having the foam down so low. You may have to settle for a slightly non-scale surfaced trim in order to achieve a properly operating sub(the boat may set a bit low). Get that foam out from under the lowest reaches of the boat and get them up higher in the deck.
                      I am not trying to beat you up here. I can pick you your aggravation. Just trying to help you out!
                      • davinci
                        • Jul 2009
                        • 68
                        right ?
                        No, I should have explained that it was sinking Level, not bow first.
                        It was going down way too fast and way too easy, not a controled desent.
                        • davinci
                          • Jul 2009
                          • 68
                          Thanks for the suggestions, Matt.
                          Hopefully
                          Hopefully the foam in ballast-chamber fixed the problem.
                          I now need to get it to the lake to test it's dynamic dive capability.
                          Since it don't look like the static dive capability will ever be what I wanted. Just too top-heavy for that.
                          • davinci
                            • Jul 2009
                            • 68
                            #28
                            I'm getting very close on
                            I'm getting very close on the flotation trim.
                            The stern sets a little low when surfaced all the way but there's No roll now, which is a big improvement.
                            But taking any weight out of the stern makes it start to roll, so it may have to stay the way it is.
                            I only have dynamic dive, below periscope depth, which is great.
                            I really don't need it to static dive.
                            • davinci
                              • Jul 2009
                              • 68
                              #29
                              With a great deal of
                              With a great deal of work I've got it at a proper level when surfaced.
                              The problem was that when they made the hull cover piece, instead of installed small buldheads to make it ridged, they used about 4 times too much resin making it 4 times heavier than it should be.
                              I used a dremel drum-sanding bit to grind out a great deal of the resin.
                              Man, what a mess with resin dust.
                              But I got topside lightened enough so I could remove some the lead from keel without it rolling.
                              It was a Major modifcation but worth it to get it riding 'High and Proud'.
                              I'll know next time to check that before buying a fiberglass hull.
                              • mike dory
                                • Feb 2004
                                • 158
                                #30
                                Howdy, Please allow me a
                                Howdy, Please allow me a second here, to THANK all those who sent me e-mails and cards while I was in the Hospital. It ment alot. It is so good to be home again... Barb and I thank all of you...
                                Now about this boat, Dont forget, you can add more of "the pink stuff" inside of the conning tower This won't do anything for your surface trim but it will help you to "catch" your boat as you dive and keep it off the bottom. This will improve your control of the boat as you dive. Next. Go to the regatta, with your boat, There will be lot's of guys there to give you a hand in triming your boat. not to mention it's just great fun... Best Wishes to all.......Mike Dory
