Arkmodel WTC
  • nzkilo
    • Jan 2006
    • 27
    Arkmodel WTC
    Hi,
    Does anyone have one of the arkmodel WTCs? Any close up pictures out there?
  • nzkilo
    • Jan 2006
    • 27
    Hasn't anyone taken the plunge
    Hasn't anyone taken the plunge with one of their pressure hulls? (no pun intended).
    Sadly the website is quite limited, I think they would get more business with more detail / pics etc.
    • subkraft
      • Jan 2009
      • 76
      arkmodel wtc
      I have. Went to China at Christmas and went down there to visit. Very interesting day, a real adventure. Came back with wtc kit and they sent hull down to Aus later.
      WTC now just about finished, gone together pretty well. Uses a pump to fill a bag fed thro a solenoid valve. Wtc is all cnc cut nylon, all a good fit.
      They can supply a pretty nifty reversing switch that runs straight out of the receiver to operate the pump and its a 12 volt system.
      My kit was a pre-production item, it was good of them to let me have it. I've made a few changes to suit myself. I replaced the supplied solenoid valve, the supplied pump just couldn't pull enough water thro it, bag filled very slow and the pump got hot. Changed the prop shaft arrangement, kit supplied with a seal and instructions not to run out of water....I put in a more conventional stern shaft.
      Overall I thought it was a good kit and reasonably priced. The Chinese characters engraved into the endcaps labelling the plug holes are pretty cool too....
      • nzkilo
        • Jan 2006
        • 27
        thanks for the info.
        I hope
        I hope the pump on my WTC is up to scratch. I haven't purchased any reversing switches yet - I'll take a look before I invest more
        • subkraft
          • Jan 2009
          • 76
          wtc pump
          The pump as supplied is really good. The problem I felt was the solenoid, the valve opening inside was just too small. Replaced with a nylon bodied valve, I carefully enlarged the internal ports and it works fine.
          • nzkilo
            • Jan 2006
            • 27
            Do you have any images
            Do you have any images you could post?
            • subkraft
              • Jan 2009
              • 76
              http://img4.imageshack.us/img4/1806/74076044.th.jpg
              http://img4.imageshack.us/img4/9950/86651069.th.jpg
              http://img44.imageshack.us/img44/7457/28717705.th.jpg
              ...okay, here's a couple as
              ...okay, here's a couple as a first go at uploading images to here.
              pix show kit as provided with the exception of the ballast inlet tubes which was a rough up. But should give an idea of the construction etc.....
              • nzkilo
                • Jan 2006
                • 27
                Hi,
                Am I correct that you
                Hi,
                Am I correct that you have the single tank WTC?
                • subkraft
                  • Jan 2009
                  • 76
                  .....yes, if you mean just
                  .....yes, if you mean just the one ballast bladder.
