Air tanks availability
  • robert f.
    • 161
    Hi all,
    does anyone have any suggestions as to where I can obtain a small air storage tank for an RCABS-R system I am planning to build? I have read through the vendor list, but I might have overlooked it.
    Or can anyone suggest a homemade solution?
    Thanks,
    Robert
    what is small ?
    btw,
    what is small ?
    btw, I believed that the tank was the WTC itself.
    I have seen gas tanks being made from soldered copper tubing. but those are for
    propel (liquid).
    • robert f.
      • 161
      Hi Ronald,
      small as in "about
      Hi Ronald,
      small as in "about 8 centimeters long, 3 to 4 centimeters diameter" .
      No, the WTC being used as air supply is the RCABS system. I am talking about the RCABS-R (R for Reverse) system.
      So, any suggestions?
      Robert
      • feet wet
        • 213
        You might check out Robart
        You might check out Robart systems. They make air retract systems for planes. I remember their air tank to be about 1.5in x 4-5 inches.
        Jonathan
          The Robart tanks work great
          The Robart tanks work great for these systems. The come in 4 different sizes if I remember right. BD.
          • hampboats
            • Nov 2005
            • 205
            Air tanks
            If you need bigger or odd shaped tanks try these
            Naugatuck has been manufacturing stainless steel and copper floats and liquid level control sensors since 1895
            You can also use refillable aerosol can]http://cgi.ebay.com/Reusable-Refillable ... 1|294%3A50[/url]
              • 880
              What about pvc pipe.
              What max
              What max pressure would we see?
              -Scott
              • robert f.
                • 161
                All great suggestions guys! Thanks!!
                Robert
                Robert
