Submarine radio help
  • darksheer
    • Nov 2008
    • 30
    well it turns out that failing to read the box is a bad thing
    i am the proud owner of a 8 channel futaba radio on the aircraft band and since its been 3 months since i got it i cannot return it
    I know subs need to be on the 75 mhz channel can someone recommend me a 7-8 channel radio that isnt one of those 800 dollar ones
    im looking to spend about 300 dollars for the radio and would like it to be a modular one
    thanks in advance
    PS anyone want picture of the U47 as it stands now
    I think Futaba can convert
    I think Futaba can convert it for you. I would call their customer service number...
    • KevinMC
      • Sep 2005
      • 463
      Which radio model do you
      Which radio model do you have? You probably don't need to send it away, just buy a 75MHz transmitter module. (I can't think of any 8ch Futaba radios that don't use the Tx module system.)
      If you've got an 8U (or similar) Futaba makes a 75MHz module that will drop right in to the back of your Tx. Alternatively, you could look into finding a HiTec Spectra 75 which will let you dial up any surface channel you want. They cost a little more but are definitely worth it.
      KMc Designs
      • darksheer
        • Nov 2008
        • 30
        unfortunatly this radio does not
        unfortunatly this radio does not have a modual
        its a futaba T7CHP
        so its a 7 channel not a 8
