I will be needing to bond styrene, urethane, cast metal, brass and aluminum parts for the sub I am working on.
My kit and instructions are from the 1984 to 1995 era. So I would like to hear any suggestions on what products you people currently are using for bonding purposes. There are two principle bonding agents mentioned in the instructions which are CA and 5-minute epoxy.
I have read about Merriman using a product called Ambroid PROWELD for "fusing" plastic to plastic. So I was thinking of going with that for my styrene to styrene attachments.
For adhering the cast metal parts to plastic, it looks like CA is best. Zap CA is specifically mentioned along with Hot Stuff (which appears to be watery and good for parts that fit very well). UFO Oderless Thick seems to be intended for bonding to foam, but is also thicker for bonding looser fitting parts.
For bonding urethane to brass or aluminum, 5-minute epoxy is recommended. I guess this would also be good for bonding brass or aluminum to styrene.. What is a good 5-minute epoxy? Maybe Devcon? What do you guys use?
Thanks,
Thanks,
