I have a NOS 1994 vintage Pittman 12volt motor with a 40mm diameter can. The motor part number is 9513B397. It will be set up as direct drive turning a 44mm diameter brass 3-blade propeller. This is to power a vintage 32nd Parallel XXIII model.
I have been unable to find any specs on this motor to figure out what its maximum AMP current draw is. I want to select an appropriate Mtroniks Viper ESC to use with this motor. My guess is that it will draw more current than the MicroViper Marine10 (10 AMP) is capable of handling.
Other ESC controllers in the Mtroniks line up have the following max AMP limits:
Marine15 (15 AMP)
Marine20 (20 AMP)
Marine25 (25 AMP)
Marine40 (40 AMP)
Can anyone confirm that my Pittman motor will require a higher than 10 AMP controller and if so what AMP limit would be safe to run with the motor and setup that I described above, or would it just be safest to use the Marine40 with it?
Thanks,
Steve
Marine15 (15 AMP)
Marine20 (20 AMP)
Marine25 (25 AMP)
Marine40 (40 AMP)
Thanks,
Steve
