operating front planes?
  • u-33
    • Jun 2008
    • 309
    OK guys, an honest opinion please…
    Is it really worth having operational front planes? Do they do much to help the boat dive, or could I rely on the rear planes only? The hull is a teardrop shaped one, by the way, similar to an Albacore, and the planes are bow (not sail) mounted.
    Rich
  • wayne frey
    • 925
    Depends on the size of
    Depends on the size of the boat.
    Smaller ones, similar to the thor alfa, it is not a big deal. However, on a larger hull, like a 1/32 scale, it would matter. Especially a bow mounted plane. The boat will react more to that than a sail mounted plane.
    • u-33
      • Jun 2008
      • 309
      The boat is just about
      The boat is just about 900mm overall length Wayne...I guess I could always mount the planes in a raised position?
      Rich
        A seawolf does not need
        A seawolf does not need front vanes, although they can sometimes add a degree of subtlety to the boats control. The rear vanes are very responsive, being large in size and sited behind the wash of the propeller.
        I'd recommend the fitting of a leveller though.
        • u-33
          • Jun 2008
          • 309
          A seawolf...........http://www.subcommittee.com/forum/icon_question.gif
          http://www.subcommittee.com/forum/icon_eek.gif
            What's the look of surprise
            What's the look of surprise all about. It is a Robbe Seawolf you're working on isn't it?
            • u-33
              • Jun 2008
              • 309
              And what makes you think
              And what makes you think that Andy?
              Rich
              (ok, it is...but you'll not recognise it as such...)
                The pictures you posted up
                The pictures you posted up on Facebook, but which were removed not long after. they looked to me like a Robbe Seawolf with a different conning tower/sail attached.
                • u-33
                  • Jun 2008
                  • 309
                  Naff...I didn't think anyone had
                  Naff...I didn't think anyone had time to see them!
                  Oh well...the cat's out of the bag then, as they say...it's a Robbe Sea Wolf V2 with a new sail, new bow planes, and much more deck/hull detail. It's based upon a cold war Russian sub that was actually never built(it never left the design table)which gives me plenty of 'artistic licence'.
                  So far it has four channel radio, the static dive system is almost done and the bodywork is in the late stages of completion.
                  I'm stood standing by for all sorts of coments...
                  Rich
                    They look very small. i
                    They look very small. i wouldn't bother making them operational.
                    Sail looks a bit out of proportion with the rest of the sub. May cause you some roll problems on turns.
                    I'd cut it down a bit i.e.-
                    • u-33
                      • Jun 2008
                      • 309
                      Point taken about the sail
                      Point taken about the sail and agreed with Andy, but there is a good reason for this,,,,the sail and the front planes are borrowed from the Blueback and when that boat becomes operational they will be going back on her, so I don’t want to start hacking and chopping the sail around. I guess the sail is about ¾” too high, but I can live with that.
                      Rich
                        I would make them operational
                        I would make them operational ,they arent that small ,I have an Scale Ships AkulaII and that sub has small scale bow planes.
                        I ran her both with and without and the best periscope keeping and depth changing manuevers was with dive planes on the bow,well worth the effort.
                        Dave
                        • u-33
                          • Jun 2008
                          • 309
                          Point taken Dave...I've made the
                          Point taken Dave...I've made the front planes operational, that way I can use them if needs be, or if I don't need to I can just leave the tx stick alone.
                          Nice Akula, by the way...I like those boats, evil looking things aren't they?
                          Rich
                          • vanguard uk
                            • Dec 2008
                            • 7
                            I'd go with working as
                            I'd go with working as well, had them working on my Trafalgar & they were very small, but had them set up as a trimming aid when dived & it made for a very stable boat, I've only got small ones on the Vanguard but I'll be wiring them up.
                              Skip had an article in
                              Skip had an article in an early SCR on an easy way to make the planes operational. Don't remember which one, I think you have a spring on one end so the servo inside just pushes against it.
