1/96 ScaleShips Oscar II Build
  • ericpw8818
    • May 2003
    • 81
    Hello,
    I have been working on and off on this boat for almost a year. Spent the first three months opening flood holes ( about 400 later ) I have installed a WTC 3.5/2, and more. Here are a few shots of where I'm at so far.
  • greenman407
    • Sep 2007
    • 1186
    Looking really good! I have
    Looking really good! I have one too but I havent started on mine yet. Tell me , How did you attach the attenuaters to the propellors?
      Nice boat.
      Be sure to
      Nice boat.
      Be sure to protect those plywood ribs from water though.
      • ericpw8818
        • May 2003
        • 81
        I covered the plywood twice
        I covered the plywood twice with epoxy resin. I silver soldered the attenuators to the props. I should polish the things up, but they are gonna look pretty cool with a little tarnish on there. I can't wait to float this thing.
        • greenman407
          • Sep 2007
          • 1186
          Did you use a big
          Did you use a big soldering iron or did you use a propane torch? And I assume you drilled and tapped the props for set screws because mine didnt come with any.
          • polaris
            • Feb 2008
            • 107
            Bring it to Gilligans Island
            Bring it to Gilligans Island this Saturday and put it through some trials .
            That is if the Deepsouth guys are going to run, and the weather holds out.
            Stuart
            • greenman407
              • Sep 2007
              • 1186
              Can you supply a picture
              Can you supply a picture of the inside of the tail section? Specifacally the multiple hookups to the rudders and planes. Its a lot of work and I thought seeing yours might provide a few shortcuts. Thanks!!!
