Akula Build Pics
  • greyakula52
    • May 2005
    • 98
    Akula Build Pics
    Andre’s Akula Build: K-267 Дракон (Dragon)
    To Those Interested In Large Models, The Next Entries May Peak Your Interests:
    [b]Short History] This Model Was Originally Developed By Bob Buchanon, A Dedicated Model Builder And Friend. His Akula Boat, A Beauty To Say The Least, Is In 1/48" Scale. I Cannot Remember How I Met Him, But I Signed On To Help. He Provided The Masters, I Provided The Raw Materials To Start Work. About A Half Dozen Pulls From The Developed Molds Yielded Varying Quality, Workable Parts From Our "Production Staff". Not Exactly What We Looking For.
    One Decent Hull Made The S/C Regatta Raffle Table, One Nice Hull Assembly As A Christmas Gift, Later Returned To Me, Two Fair Units Made It To Bob. I Was Glad He At Least Got Several Units To Work. We Commissioned, Paul Chamberlain, In The UK To Produce Props For Us. Outside Of The A Few "Historical Facts" We Settled On. Bob Developed Several Versions That Were Reproduced By The Lost Wax Process. Let Me Say This, If You Have Not Seen One Of These Babies Close Up, You Are Really Missing A True Artisan's Work. Pictures Will Follow Of These.
    With My Hull Parts, The K-267 Dragon, Started As A Top Only, Natural Epoxy Colored And With Few Air Voids. I Had To Cast The Lower Hull Myself. The "Returned" Hull Would Be A First Generation Boat. Well, All Things Being Equal, I Found This Was Not Going To "Pan Out". After Close Examination, The Lower Mold I Had, Was Unusable. Switching To The "Returned" Boat, The Top Of The Unit Had Air Voids As Large As My Thumbs, Making It Usable For Practice Only. The Lower Hull, Thinner Than My "Beige Top Unit, Was Now The Way I'd Have To Proceed. The Working Hull Now Sports This Lower Section Of The Returned "Gifted" Unit. Considering Everything Else, This Worked Out. The Lower Hull, Dyed Black, Didn’t
    Come Out As Envisioned. It Was Thin And Brittle. I Had To Think About What I Could Do. Adding More Epoxy And Cloth Might Work.
    This Idea Was Tossed, As I Would Have To Lift This Boat Alone At Some Point. Age Should Make You Smarter. Well, What I Did Was To Make A Set Of Ribs And Longitudinal Runners, To Transfer And Spread All Flexing Forces Throughout The Center Of The Hull Structure. See These Photos Later. Note: Everything Is Hand Formed
    From 1/8 inch G-10 Fiberglass Sheet, With The Exception Of The Center Rib Which Is ¼ inch Thick. All Runners Are 3/16 G-10 Rod.
    More To Come!
  • greyakula52
    • May 2005
    • 98
    New Pics
    Some Additional Photos...... I Hope They Come Out Okay!
    Tell Me What You Think!
    • emspaul
      • Aug 2008
      • 93
      Hi Andre,
      I have a question
      Hi Andre,
      I have a question for you .
      Why is there such a large space between the Prop and tail section?
      I have started on my first Akula and the plans that I have it seems to be a lot closer.
      Am I looking at this wrong?
      I would hate to show up with it some where and have people laugh at me for doing it the wrong way.
      Most people laugh at me after they get to know me.
      Paul
      Homeport Models: The experts in accurate, hand-built scale model ships. Specializing in modern US Navy & Coast Guard warships for display and RC use.
      • shadowpeo
        • 82
        Take a look at the
        Take a look at the scale ships akula, thye offer from what I have heard the most accurate akula available
        http://scaleships.biz/images/akula/akula24.jpg
        • emspaul
          • Aug 2008
          • 93
          My plans are wrong
          My plans are wrong
          Paul
          • wayne frey
            • 925
            My book has some decent
            My book has some decent drydocks of the Akula that can help also.
            I used to be in contact with Bob Buchannon, but have lost track of him. Does anyone know how to get him? Email me if you do.
            I have pictures of Bob's Akula also. His detail is fantastic! And for the time, his information was very good also.
            • fgroza
              • Jun 2005
              • 168
              The hull from Scale Shipyards
              The hull from Scale Shipyards is one of the short tails. You need to add the stinger to make it correct. I believe at the time the plans were drawn by D. Merriman, not much was known about the sub. Sometimes this type of info has to be guessed at until actual photos are viewed. My Akula is one of the short tails but I'm going to run it this way.
              Frank
              • emspaul
                • Aug 2008
                • 93
                Okay,
                I can turn one out
                Okay,
                I can turn one out of brass and use that as the bearing?
                Or do I need to make it out of plastic?
                Paul
                • Rogue Sub
                  • 1724
                  your call ive seen plastic
                  your call ive seen plastic brass, bondo, and epoxy used. What workes best of you really. The brass would be darn strong though if you dont have weight issues. I had to add a bit of weight to the aft end of my scale ships akula though.
                  • greyakula52
                    • May 2005
                    • 98
                    1/48 Scale Akula Photos Set 1
                    Here Are Some Self Explaining Photos.
                    Lower Hull Internal Details
                    Bow On View
                    Stern Detail
                    Initial Control Placeholder Setup
                    • greyakula52
                      • May 2005
                      • 98
                      Additional Build Shots
                      Finding Out Early
                      Finding Out Early Your Building The WRONG Boat!
                      I Started Out Making The "limber Ports" Way Too High On the Hull.
                      Filling and Opening New Below The First Set. Only the Midships Work Was Close... So I Left Them Alone. I'll Not Tell If You Won't. Remember, Rivet Counters, This Boat Will Not Be In A Museum, But Water!
                      Initial Bow Planes Placement][/url]
                      Correcting Hull Opening Errors][/url]
                      • greyakula52
                        • May 2005
                        • 98
                        1/48 Scale Akula Photos Set 2
                        The Idea Of Using Shipping Tape Gave Me An Idea For
                        Forming "Exact" Fitting Hatches.
                        Here Is What I Tried On The Top Hull
                        Oops...... I Forgot To Put In The Release Agent Doooooooh!
                        Now I Know What Not To Do On The Sail Hatchwork!
                        Just Putting The Boat In Perspective!
                        Very Impressive!........ Impressive Indeed!
                        • myles yancey
                          • Mar 2005
                          • 282
                          your doing some nice work,
                          your doing some nice work, keep the pictures coming
                          Myles
