Seawolf prop comes lose
  • xxl
    • Jul 2008
    • 79
    Haveing a hard time keeping my seawolfs prop glued on to the shaft i the one from caswell any ideas
  • Rogue Sub
    • 1724
    what are you using?
    How tight
    what are you using?
    How tight is the fit?
    DO you clean the area before re gluing it?
      glue it with goop! it
      glue it with goop! it will come off when you want it to.
      • wingtip
        • Dec 2004
        • 337
        Is this metal to metal?
        Is this metal to metal? Loctite is your friend. Blue is the common, red really works but requires heat to get the parts seperated again...
        • Rogue Sub
          • 1724
          It is SS with a
          It is SS with a plastic spacer on it and the prop is white metal. I used CA to attach mine and it worked fine. Perhaps some thin set to penetrate better?
