'scopes n' stuff...
  • u-33
    • Jun 2008
    • 309
    'scopes n' stuff...
    OK, I've spent a happy hour drilling and filing out all the holes in the conn tower for the 'scopes and other bits and pieces to go through.
    Question : what's the favourite way to attach the 'scopes and bits inside the tower? Do I make up a wood former inside the tower and drill it and glue the 'scopes in? Or a brass/alloy/plastic one?
    Kit is the Steve Neill U-212, so there's but very little room inside the tower.
    Rich
  • petn7
    • 616
    Wait...how did you get Steve's
    Wait...how did you get Steve's U-212 kit?!
    I thought they weren't available??
    • Rogue Sub
      • 1724
      I would use a sheet
      I would use a sheet of plastic for the base and then silicone them in place incase you need to remove them for repair. You would be surprised how often you get run over when there are surface craft around.
      • stark
        • 243
        Soon the Re Mastered version will be out, see the model in this thread.
        http://www.subpirates.com/viewtopic.php?f=31&t=3415
        Brian
        • u-33
          • Jun 2008
          • 309
          Ahh...it's not who you know, it's what you know ABOUT who you know.
          Rich
          • mike dory
            • Feb 2004
            • 158
            Guy's - You might consider,
            Guy's - You might consider, staying away from "wood" Even with several coats of sealent and paint, water seems to find away into wood Best Wishes Mike Dory
            • u-33
              • Jun 2008
              • 309
              I'm not overkeen on using wood for the reasons you state Mike, so I'm working towards either plastic or alloy.
              Rich
                I have an unstarted Steve
                I have an unstarted Steve Neill 212 hull kit that it doesn't look like I am going to be able to get to. If anyone's interested, send me an email.
                tmsmalley@yahoo.com
                Tim
                  message sent Tim
                  message sent Tim
