Engel Static Depth Controller - I do not understand
  • rockpile
    • 48
    Jaut received the TAES Static Depth Controller upgrade kit from ENGEL.
    I am useing the robbe Futabe FC-16 radio System in my 1/32 Fleet Boat and 1/32 Tyoe IX. I have the TAE pistons tanks installed and operating properly in the boats. Execlant trim and submerged running.
    I wish to install the (Static Depth Controller) in both boats. Reading the instlation instructions for the unit into the boat is understood.
    I do not understand the transmitter setup. As per instructions,
    (" The TAES processes four different commands which must be directed individually. Therefore, it is advisable to control the TASE via a proportional shifter on the transmitter").
    PLEASE What is a PRORTIONAL SHIFTER )?
    I am not able to find any information in the robbe Futaba system Manual.
    My system is set up with Twin stick , a Multi-Prop Modul/ Multi-Prop Decoder , Multi-Switch Modul / Multi-Switch Decoder. (2) two Linear poportional channels.
    Any help would be greatly appreciated.
  • jlemons
    • 11
    It's a linear proportional slide.
    It's a linear proportional slide. You can purchase this from Robbe. The part number is f1501.
    Edited By jlemons on 1057255264
    • rockpile
      • 48
      Thanks James,
      I have 2 of
      Thanks James,
      I have 2 of those installed in the transmitter.
      part # 1601 ?
      they are set up now to have the center off. Is this correct?
      Thanks for the help.
      Jack
      • jlemons
        • 11
        The way mine is setup.
        The way mine is setup. All the way forward is full dive, 3/4 is hover, 1/4 is stop dive, all the way back is surface.
        • ramius-ii
          • Apr 2003
          • 393
          Hi Jack & James]http://www.subcommittee.com/forum/icon_smile.gif
          Hi Jack & James]http://www.subcommittee.com/forum/icon_smile.gif[/img]
          • rockpile
            • 48
            Looks like the answer that
            Looks like the answer that I needed. Thank you all for the help
