Hi guys.
If you were to build a ballast tank app. 7inch long, diameter 5½inch, would you then place dividers with small holes in them, inside the tank to prevent the water from moving freely inside a half-full tank?
(The tank will be placed in the buoyant center of the sub, in the middle)
I'm having slightly mixed feelings about it.. Slowing down the movement of the ballast water will also prevent the water from running back to the "right place" quicky..
