Hmm, that is a strange
Hmm, that is a strange size for the WTC diameter 37mm (1 15/32"). I am going to guess maybe it is 1.5" even, and that must be the outside diameter. Is the inside diameter 1 3/8"?
That is going to be the exact outside and inside diameter of the WTC for my project.
I looked at the SWM page and that 300-sized motor appears to me to be 15/16" or the same diameter as a Quarter. Your old Mabuchi motor looks like a speed 250 size motor, which is what I am considering for my WTC. These 250 motors typically spin 9722 RPM @ 5V The SWM 300 motor claims to spin 5400 RPM @ 5V. Supposedly the lower RPM should be better for a boat or sub, and not need a reduction gear setup.
I was trying to find out the diameter to see if i'd have sufficient room to clear a pushrod both above and below the motor in my tube. I see you put a bend in your pushrods to get them closer together to be able to pass through your seals.
My project will be a small boat also, similar in size to yours. Thanks for the close up photo.
