[color=#000000]]
Revell of Germany VII Uboat 1/72 - it's shipping early!
Tags: None
Hello, I have built a
Hello, I have built a 1/72 scale type VIIc to look like U-552 around 1942 time frame. It started out as a combat models vacuum molded kit and after many changes, much scratchbuilding, and remolding the hull in fiberglass, now is an operational static diving model. The model length at 36 inches sounds impressive but be aware that this equates to less than 3" of internal width and height at the widest point in the hull. It is possible but go into this with no illusions. I made my own WTC out of Lexan and split the hull vertically just after the "saddle tanks" with the cap for the WTC attached to the aft part of the hull. The lexan tube affords me 2" internal diameter by 13" length of space to "fill". I drive the boat with a single 12v motor powered by an OTW ESC with BEC through an external gearbox driving both shafts counterrotating. I have an OTW levelling device connected to my rear dive planes and a slotted pushrod to move the forward dive planes as well with the same servo but outside the operational area of the leveller. A second servo operates the twin rudders. I use a pump system (refuelling pump) with a 250ml IV bag for the ballast tank inside the lexan tube. I power the whole system with an 8.4v ni-cad pack in the free flooding areas split in 2/3 fwd of the WTC and 1/3 aft and waterproofed with tool dip. I have included a link to some photos of the finished boat, but if you want more info you can contact me by e-mail. mgodding@gokenora.com I am interested in seeing the new Revell type VII as well, if nothing else to see how much less work it would have been. Good Luck.
Mike Godding, Kenora, Ontario, Canada
http://community.webshots.com/album/68554398nZwJcZ
Edited By mike42rc on 1056033722
Turbobearcat, I called and tried
Turbobearcat, I called and tried to find someone who listed that kit and couldn't. I did find it in Europe but the going price in US $ is from $66-76 which I think is about what I would have expected for a model this size.
John
I talked to the hobbieshop
I talked to the hobbieshop in Portage Michigan, he said the kit is showing up and for a very low price, he ordered 6 units
and I have 2 of them for $22 U.S dollars each. From what I was told that price we have locked so maybe I lucked out.
Turbobearcat
Here are a couple of
Here are a couple of hits I found. Revell 05015
John
