Best radio for Subs
  • corsaire
    • 166
    Best radio for Subs
    I want to start shopping for a radio for my Akula and looking for feedback. Although a 4 or 5 channel will do I'd like to have more options like perhaps 8-9 channels for future projects. So far, I've been recommeded two, both w/ pros and cons: F-14 Robbe Navy and the Futaba DX 7 radio, different technologies bit the latter gives you cutting edge, etc.
    Which would you recommend and what works well for you?
    Thanks,
    Brian
  • wingtip
    • Dec 2004
    • 336
    8 channel polk radio... 180
    8 channel polk radio... 180 bucks, fully programmable, fully synthesized so no crystals or channel conflicts, 99 model memory, and its 75 mhz, will work with any rx no matter what brand...
    just hard to beat...
    visit http://www.caswellplating.com/models/ to order yours...
      Brian,
      Is that a Futaba DX
      Brian,
      Is that a Futaba DX 7 or a Spektrum DX 7? I'm not sure what model Futaba that might be, but if it is the Spektrum radio do *not* get it for r/c sub use. The 2.4GHz signal does not penetrate the water....which means that you would have no sub-surface control of the sub.
      • corsaire
        • 166
        Jee, thanks Jeff for the
        Jee, thanks Jeff for the advise, I had been very tempted for such technology but I guess not everything cutting-edge is good for our type of application.
        Brian
        • corsaire
          • 166
          just hard to beat... <<<<<<<<<<<<
          Dave,
          Is it reliable and sane quality as Futaba ? Does it work w/ Futaba sevos?
          Thanks,
          Brian
          • wingtip
            • Dec 2004
            • 336
            yes it will work with
            yes it will work with futaba servos..and you will find most bubble heads use the polk line of radios...
            the only thing i wish it had was digital trims lol...
              There are a number of
              There are a number of vendors that re-sell the Polk Tracker radios. You may also want to check out Mike's Subworks and Dark Horse Models as they also carry those radios.
              Quite a number of SubCommittee folks have either the Tracker II or Tracker III radios and have a lot of good things to say about them.
              Futaba servos are reported to work just fine.
              • wolfsong
                • Jan 2005
                • 189
                i have the trackerIII myself..
                i have the trackerIII myself.. works with any receiver / any servo, positive or negative shift..
                great radio
                stefan
                  ...and it won't let you
                  ...and it won't let you power up if someone else is transmitting on the same freq and extra batteries are CHEAP!!
                  • corsaire
                    • 166
                    Nuff said...I'm ordering one soon
                    Nuff said...I'm ordering one soon enough.
                    Thank you all!
                    Brian
                    • Rogue Sub
                      • 1724
                      Yup I am using a
                      Yup I am using a polk tracker 3 with my Scale Ship Akula aswell
                        I had one and got
                        I had one and got rid of it ,I could not get rid of the glitches! And at the last fun run Nuke power had alot of trouble with his.I stick with Futaba,JR radios that will always be around and have the best reputations.The Polk unit is being dicontinued.
                        • petn7
                          • 616
                          I have a Futaba 8UHFS
                          I have a Futaba 8UHFS and I'm very happy with it.
                          Futaba all the way!
                            The Polk unit is being di[s]continued.
                            Well, to be fair.....it looks like all r/c vendors are rapidly moving along the path to 2.4GHz for both air and ground use. If folks actually do stop making radios in the 75MHz band, then all of us are going to have problems buying any new radio.
                            I did read on the Polk Hobby site that they were/are looking to retain the 75MHz systems for surface and sub-surface use. It would be nice if this could be confirmed as still the case.
                            • warpatroller
                              • Feb 2006
                              • 308
                              What is with these posts
                              What is with these posts about glitch problems with the Tracker III? I have one on order, and now I am wondering if I made a mistake... I thought this was a good sub Tx/Rx setup. I like the idea of not screwing around with the crystals. What if your running your sub alone somewhere and not with other RC boaters...have people had this glitch problem and loss of sync with the Seeker receiver when they are operating alone and not around other RCers?
                              I had to order the 8 channel set and an additional 6 channel Seeker, because the 8 channel will not fit in my WTC. An airplane with a 2.4Ghz radio setup is looking to be less of a headache than a submarine every day lol.
                              Seems like I recall the circumstances for the Tracker III problems being when there are a group of people running boats together and indoors at that.
