Micro receiver on the 27 or 75 Mhz FM band
  • petn7
    • 616
    Does one exist? I'm referring to the kind of micro receivers used on park slowfliers. I can only seem to find them on the 72 Mhz and 2.4 Ghz frequencies.
    I ask this because I want to have a tiny receiver on a legal frequency.
  • wingtip
    • Dec 2004
    • 336
    bottom 5 on this page
    http://www.robotmarketplace.com/marketp
    http://www.robotmarketplace.com/marketp ... ivers.html
    but most standard sized ones can have the case removed and make them smaller like some of the other ones on that page
    • petn7
      • 616
      Ahhh, good find.
      Ahhh, good find.
      • aeroengineer1
        • May 2005
        • 241
        2.4 Ghz is a bad
        2.4 Ghz is a bad option, do not use. Between 27 and 75 there is little practical difference in penetrating power. 2.4Ghz is the resonance frequency of water, and hence no signal goes through, but tends to be reflected off the surface.
        Adam
        • petn7
          • 616
          2.4 Ghz is a bad
          Adam
          Yeah, I know.
          I've read a few things from other boards, as well as generally assumed that since our real life subs use very low frequencies to send radio waves through seawater, lower the frequency, "better" the underwater transmission.
          Too bad I can't get a 27 Mhz micro radio system
          • chips
            • 497
            Sombra Labs Shadow 3 Synthesized
            Sombra Labs Shadow 3 Synthesized receiver on 72/75 MHz works very well. Get the rx/programer combo first, then add more rx as needed. I've got them in two subs and they work perfectly.
            • fung pang
              • 91
              two Shadow 3 could set
              two Shadow 3 could set up for 16 channels, to find a 16 channels 75 mhz that's hard.
              and for a 27 mhz system.
              try
              http://www.megatech.com/product_detail_ ... hp?ID=7320
              or look around for a cheap one make for parkflyer, get one for $25 at the WRAM Show.
              • david h
                • 199
                Micro recievers
                Hello,
                I don't know much about the frequencies that you are using. We use 36 Mhz here in Oz. However I recently picked up a small RC Electric Helicopter receiver for about $35 Au. Thinking, oh it's cheap It must be good for something,..
                It's an ALIGN RC RX6 receiver and I've put it in my sub and it's been great!!!! You do need to get good chrystals for it though. HITEC ones usually do the job..
                regards,
                David H
