Thankyou Subculture for the info
Thankyou Subculture for the info on Sheerline
Here you can see the two motors and the pinion gears.But instead of Ca I am going to use red locktight.
Thatll larn ya darn ya!
Its easy to see the evidence of a smoked motor by the discoloration of the plastic on one side. It didnt hurt anything though. Next I rough up the areas of the motor cans that will come in contact with the motor mount and use GOOP to make the attachment.
After the attachment is done it will be time to put everything back together again and get it in the water for some more testing. But first take note of this.
If you can zero in on this you can see the gears inside the endcap that the pinions mesh with to provide the 3 to 1 gear reduction that helps make this thing work.
Notice the intense concentration on my face , now thats dedication to the sport.
You can see here how it sits a little low in the stern, not too bad though.
Other than a slightly bent periscope it looks pretty good. Starboard to port balance also seems good.
Dont worry, Kowalski and the Chief are inside working hard to fix the errant powerplant, the world is depending on them!
