It is time to put
It is time to put on some Cadillac fins. First ,they come in two pieces for each side. Since I wanted this Sub to be lighted I had to make provision for two lights in the fins. To do that I took some 1/8" brass tube and curved it and installed it in such a way as to allow relatively quick change of a light bulb when the time arrived. I terminated one end about 3/4" inside at the top of the fin to allow room for the bulb itself but also room for the lenses to partially recess themselves inside the fin to give them something to glue to. The other end I allowed to run wild. As it was to penetrate the hull it could help line up the fin and give some support. Its important to note that there is supposed to be a 90 degree( there is no degree symbol on this keyboard) angle between the two fins themselves and a 45 degree angle between the fin and the vertical centerline. After epoxying the two halves together and carefully marking the hull it was time to mix the epoxy. As usual it was tacked into proper position with CA. Then I took masking tape and made a dam underneath the fin and extended it upwards at both ends to trap the liquid epoxy from flowing out of the joint.
Now the hard part. Just to be different I wanted to put a wide fillet in the joint but because it would be highly visible the filet had to be perfect. I choose Green Squadron spot putty as it was readily available( read,,, it just happened to be what I had in my junk drawer at the time). I didnt realize at the time that my filet was going to be so wide and deep that the putty would crack as it cured. Oh well, I used the dremel to open up the cracks and put on more putty. Now to make it perfect I took a no. 2 pencil ( because thats what I had in my junk drawer) and wrapped it with sandpaper(220 grit) and started to sand the filet. It took a couple of sanding sessions and applications of putty but it turned out great.
The other bad thing about this stuff is it takes a lot of paint to ( relatively speaking) get the spot puttys surface texture to match the otherwise smooth finish of the gelcoat. Unfortunately I dont have any closeups of this operation but I hope you guys get the drift of what I am trying to show you.
I know that most of this stuff is basic to most of you but its a show and tell that I am having fun with. So humur me. Also heres a link that I would like you to check out. It is a website put together by Ben Cliffe from Canada. It contains excellent quality video and still photography. In it you will see some action videos of subs taken from underwater, quite a different perspective than what most of us are used to seeing. And low and behold there is even a Seaview in there. I wish you all a good evening!
http://www.bcliffe.com/subs/Submarines.html
