JOMAR dual E switch help plz
The negative lead from you
The negative lead from you motor, light, (device) goes to the + in the Jomar switch. The - from the Jomar switch goes to ground on your battery(-).
In other words in a simple light bulb circuit one + wire from the batt to the bulb. One - wire from the batt to the bulb. Now cut the negative wire and insert the Jomar switch. The negative wire from the bulb goes to the positive wire on the Jomar switch, the negative wire on the jomar switch then continues the circuit to the negative batt terminal. Its just like inserting a hardware toggle on/off switch on the negative side of the simple light bulb circuit.
